Blueprint - automation - “Automation is unavailable”
This is a double post since I am not sure if it is directly related to the blueprint I am using or this is some other reason. What could be wrong and how can I get the “device id” see below.
I get: `“Automation is unavailable”. after recent update of HA and the automation stopped working:
When I try to change/correct the automation I get: “Message malformed: unknown device”.
the automation yaml:
alias: Udate Notification
description: >-
  https://community.home-assistant.io/t/update-notifications-core-hacs-supervisor-and-addons-now-a-blueprint/182295
use_blueprint:
  path: mdegat01/update_notifications.yaml
  input:
    reminder_hours: "3"
    update_entities:
      - update.home_assistant_core_update
      - update.esphome_update
      - update.file_editor_update
      - update.glances_update
      - update.home_assistant_operating_system_update
      - update.grafana_update
      - update.home_assistant_supervisor_update
      - update.influxdb_update
      - update.mosquitto_broker_update
      - update.mariadb_update
      - update.mqtt_explorer_update
      - update.node_red_update
      - update.samba_backup_update
      - update.samba_share_update
      - update.sqlite_web_update
      - update.traccar_update
      - update.z_wave_js_update
      - update.studio_code_server_update
      - update.ssh_web_terminal_update
    mobile_app_device: 7ba2dc2804c0d84f75ad1d3084663c05
    send_to_ha: true
Tried to delete the device via gui and reselect does not work.
I see:
github.com/home-assistant/core
Automations referencing non-existing devices do not work after installing 2023.11.0b1
opened Oct 27, 2023
iridris iridris
The problem After upgrading to 2023.11.0b1 from b0, multiple device IDs cha
But I cannot really find a solution or find how to change the mobile_app_device id
What should I do the get it going? What “device id” should I use? Where is that?
What changed? How to solve?
Hey, is anyone able to help out?
Solution was posted on the other thread. Just for reference for anyone ending up here with this issue.
Summary: the devices that receive notifications marked as “optional” are not optional at all anymore.
