Hello, I’m trying to create a blueprint with trigger_variables and a template trigger. However, the trigger is never fired. I tried setting the states of the entities used in my automation, and while the developers show true/false respectively, the trigger never fires. Is this not supported?
Automation Debug
Blueprint Config
alias: Storage / Vent / Turn Off
description: ''
use_blueprint:
path: _custom/vent_humidity_temperature_off.yaml
input:
target_entity:
entity_id:
- fan.storage_vent
humidity: sensor.storage_humidity
humidity_ref: sensor.e01_tf_humidity
temperature: sensor.storage_temperature
temperature_ref: sensor.e01_tf_temperature
temperature_offest: 0.5
humidity_offest: 1
Automation Config
trigger_variables:
humidity_offest: 1
mode: single
max_exceeded: silent
value_template: >
"{{ ((states(humidity)|float(0) < (states(humidity_ref)|float(0) +
humidity_offest|float(0))) and
(states(temperature)|float(0) < (states(temperature_ref)|float(0) + temperature_offest|float(0)))) }}"
- service: homeassistant.turn_off
entity_id:
- fan.storage_vent
description: ''
Developer Tools / Template
This is the template I used in the developer tools that shows the correct true
/false
outcome:
{{ ((states('sensor.storage_humidity')|float(0) < (states('sensor.e01_tf_humidity')|float(0) + 1|float(0))) and
(states('sensor.storage_temperature')|float(0) < (states('sensor.e01_tf_temperature')|float(0) + 0.5|float(0)))) }}
Full YAML
Blueprint
blueprint:
name: Humidity & Temperature Trigger Off
description: "Turn off an Entity or multiple Entities when humidity or temperature threshold is exceeded"
domain: automation
input:
target_entity:
description: The entity/entities to turn off.
selector:
entity: {}
humidity:
description: The humidity sensor.
selector:
entity:
device_class: humidity
humidity_ref:
name: Humidity Sensor Reference
description: The humidity sensor used as reference.
selector:
entity:
humidity_offest:
description: The humidity offset to turn on the vent.
default: 0
selector:
number:
min: -100
max: 100
step: 0.1
unit_of_measurement: "%"
temperature:
description: The temperature sensor.
selector:
entity:
device_class: temperature
temperature_ref:
name: Temperature Sensor Reference
description: The temperature sensor used as reference.
selector:
entity:
temperature_offest:
description: The temperature offset to turn on the vent.
default: 0
selector:
number:
min: -100
max: 100
step: 0.1
unit_of_measurement: "°C"
trigger_variables:
humidity: !input humidity
humidity_ref: !input humidity_ref
humidity_offest: !input humidity_offest
temperature: !input temperature
temperature_ref: !input temperature_ref
temperature_offest: !input temperature_offest
mode: single
value_template: >
"{{ ((states(humidity)|float(0) < (states(humidity_ref)|float(0) + humidity_offest|float(0))) and
target: !input target_entity
Automation
- id: "e09_vent_off"
description: ""
use_blueprint:
input:
target_entity:
entity_id:
- fan.storage_vent
humidity_offest: 1
