[Blueprint] Denon AVR Quick Select Automations & Buttons
[Blueprint] Denon AVR Quick Select Buttons
Control Quick Select Modes on Your Denon AVR with Home Assistant!
I’ve created a Home Assistant blueprint that allows you to easily create buttons to trigger Quick Select options (1-4) on Denon AVR devices supported by Home Assistant.
If you’re already using your Denon AVR with Home Assistant, this blueprint will simplify setting up automations or widgets to control Quick Select modes directly from the UI.
Features
  • Control Quick Select: Trigger Quick Select modes 1 through 4 on any Denon AVR with network control (tested with AVR-X3800H).
  • Simple Setup: Just select your Denon AVR from a dropdown and choose the Quick Select option (1-4).
  • Customisable: You can create multiple buttons for different Quick Select options, perfect for easily switching between input modes and settings.
How to Use
  1. Import the Blueprint
    • Use the import button to import the blueprint:
    • Alternatively: Go to Configuration > Blueprints > Import Blueprint, and enter the GitHub Gist link: https://gist.github.com/dotWee/147366eb064bdf9934f4e2531140c1ad
    • To import manually, copy the YAML from here and save it as denon_avr_quick_select.yaml in your Home Assistant’s blueprints/automation folder.
Create Automations
  1. Create Automations
    Once imported, you can create automations using the blueprint:
    • Select your Denon AVR entity from the dropdown.
    • Choose the Quick Select number (1-4) you want to trigger.
  2. Example Automation
    Here’s a sample automation using Quick Select 1:
alias: Quick Select 1 for Denon AVR
use_blueprint:
  path: your_blueprints/denon_avr_quick_select.yaml
  input:
    denon_entity: media_player.YOUR_DENON_AVR
    quick_select: 1
Just replace YOUR_DENON_AVR with the entity ID of your Denon receiver.
Example Lovelace Button Card
You can also create buttons in your Lovelace dashboard to trigger these Quick Select modes:
type: vertical-stack
cards:
  - type: button
    name: Quick Select 1
    tap_action:
      action: call-service
      service: denonavr.get_command
      service_data:
        entity_id: media_player.YOUR_DENON_AVR
        command: "/goform/formiPhoneAppDirect.xml?MSQUICK1"
  - type: button
    name: Quick Select 2
    tap_action:
      service_data:
        command: "/goform/formiPhoneAppDirect.xml?MSQUICK2"
  - type: button
    name: Quick Select 3
    tap_action:
      service_data:
        command: "/goform/formiPhoneAppDirect.xml?MSQUICK3"
  - type: button
    name: Quick Select 4
    tap_action:
      service_data:
        command: "/goform/formiPhoneAppDirect.xml?MSQUICK4"
Why This is Useful
The Quick Select feature on Denon receivers allows you to store your preferred settings, like input source, audio mode, and volume level.
This blueprint makes it easy to switch between these presets with a simple button press in Home Assistant.
Requirements
  • Denon AVR with network control (tested with AVR-X3800H, should work with many other models)
  • Home Assistant (Core or Supervised)
Feedback & Contributions
Feel free to try it out and let me know if you have any issues or improvements! You can also contribute to this blueprint by providing feedback or comments via the GitHub Gist.
I imported this Automation to Quick Select my Denon AVR X4800H.
I tried to use it in an Automation, but when the Automation is triggered i got the following error:
Error rendering data template: UndefinedError: ‘quick_select’ is undefined
Is it because i renamed the Quick Selects on my Denon AVR?
Regards, Tarandor
Normally custom names for the Quick Selects (set in the Denon device config or App) shouldn’t cause this error. This is because the actual commands sent to the Denon device are hardcoded, eg. MSQUICK1 for the first Quick Select.
A Quick Look through Denon’s API docs and the Denon Home Assistant plugin suggest no breaking changes.
I can only suggest removing the automation including the blueprint and trying it again. :face_with_peeking_eye:
I’m getting the same ‘quick select’ is undefined error on my X3100W. Importing the blueprint again does not work. It could be because my X3100W is not officially supported by Home Assistant? But then again, it is recognized just fine, and I can control other things such as on/off and volume in Home Assistant.
Any thoughts?
