Blueprint error: Unknown entity registry entry
I’m creating my first blueprint and I have it as such
blueprint:
  description: Turn on/off exhust fan automatically
  domain: automation
  input:
    humidity_entity:
      name: Humidity Sensor Entity
      selector:
        device:
          entity:
            domain:
              - sensor
            device_class: humidity
    exhaust_fan_switch_entity:
      name: Exhaust Fan Switch
      selector:
        device:
          entity:
            domain:
              - switch
    humidity_threshold:
      name: Humidity Threshold
      description: Humidity Percentage to trigger exhaust fan
      selector:
          number:
            min: 0
            max: 100
            unit_of_measurement: "%"
            mode: box
  - platform: numeric_state
    entity_id: !input humidity_entity
    for:
      hours: 0
      minutes: 0
      seconds: 10
    above: !input humidity_threshold
    below: !input humidity_threshold
  - platform: state
    entity_id: !input exhaust_fan_switch_entity
    to: "on"
    for:
      hours: 0
      minutes: 10
      seconds: 0
condition: []
  - if:
      - condition: trigger
        id:
          - on_humitidy
          - on_switch
    then:
      - service: switch.turn_on
        data: {}
  - if:
        id:
          - off_time
          - off_humidity
    then:
      - if:
          - condition: and
            conditions:
              - condition: state
                state: "on"
                for:
                  hours: 0
                  minutes: 10
                  seconds: 0
              - condition: numeric_state
                below: 65
        then:
          - service: switch.turn_off
            data: {}
mode: single
The blueprint loads fine but when I try to use it and click save i’m getting
Message malformed: Unknown entity registry entry b8b84274f06ef2cc6f9e414542e9666c
Not sure how to debug this or what the error might be
You have device selectors on the inputs and it looks like most of the rest of the BP you are using entities. Use one or the other, and I strongly suggest use all entities.
Thanks, my intent was to use entities but I didn’t catch the input being device. I must have copied the wrong section from the docs
Thanks!
