I am trying to use the new template entity blueprint feature that came with 2024.11. The goal is to have a binary sensor that is on when a timestamp sensor is soon – with a blueprint input for how much soon is.
I came up with the following blueprint:
blueprint:
name: Create a binary sensor based on the temporal distance to a timestamp sensor
description: bla
domain: template
input:
reference_entity:
name: Timestamp sensor to use
description: The sensor which needs to be observed
selector:
entity:
domain: sensor
device_class: timestamp
distance:
name: What distance to use
description: blubb
selector:
duration:
variables:
reference_entity: !input reference_entity
dt: '{{ states("sensor.restabfallsammlung")|as_datetime }}'
delta: "{{ timedelta(days=distance.days, hours=distance.hours, minutes=distance.minutes) }}"
binary_sensor:
state: >-
{% set dist = dt - now() %}
{% if dist < delta %}
on
{% else %}
off
{% endif %}
availability: "{{ states(reference_entity) not in ('unknown', 'unavailable') }}"
and I use it like this:
- unique_id: F384C743-330B-44BB-AA37-8547320F0D13
name: Anzeige Restabfallsammlung
use_blueprint:
path: dev/in_the_next.yaml
input:
reference_entity: sensor.restabfallsammlung
distance:
days: 10
minutes: 0
hours: 0
But this does not work, and I cannot figure out why. The log says:
Logger: homeassistant.components.binary_sensor
Quelle: helpers/entity_platform.py:599
Integration: Binärsensor (Dokumentation, Probleme)
Erstmals aufgetreten: 08:12:38 (8 Vorkommnisse)
Zuletzt protokolliert: 08:23:58
Error adding entity binary_sensor.anzeige_restabfallsammlung for domain binary_sensor with platform template
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 633, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2735, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.12/site-packages/jinja2/sandbox.py", line 394, in call
return __context.call(__obj, *args, **kwargs)
TypeError: unsupported type for timedelta minutes component: LoggingUndefined
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 599, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 918, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1367, in add_to_platform_finish
await self.async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/template/binary_sensor.py", line 271, in async_added_to_hass
await super().async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 578, in async_added_to_hass
async_at_start(self.hass, self._async_template_startup)
File "/usr/src/homeassistant/homeassistant/helpers/start.py", line 71, in async_at_start
return _async_at_core_state(
File "/usr/src/homeassistant/homeassistant/helpers/start.py", line 36, in _async_at_core_state
hass.async_run_hass_job(at_start_job, hass)
File "/usr/src/homeassistant/homeassistant/core.py", line 949, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 491, in _async_template_startup
**self._render_variables(),
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 347, in _render_variables
return self._run_variables.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/script_variables.py", line 62, in async_render
rendered_variables[key] = template.render_complex(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 254, in render_complex
return value.async_render(variables, limited=limited, parse_result=parse_result)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 635, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: unsupported type for timedelta minutes component: LoggingUndefined
To me, this seems to indicate two problems:
Something with the minutes component of the timedelta object. I replicated the exact same template in the template playground, but there it works fine.
Some logging component seems to be missing. I think this is not fixable on my end, and could be a bug in the core.
Any ideas?
