G’day everyone,
I hope I’ve adhered to the rules with this post but I thought I’d give it a try. First time for everyone, right?
I recently purchased a Fibaro Swipe and there doesn’t seem to be any easily-found simple automations or blueprints for it.
I was already using the blueprint by makeitworktech who has modified another but for a different device, so some of this code will be slightly third-hand.
Anyway, here it is, tested and working for my Fibaro Swipe.
Enjoy, hack, pull apart, modify and have fun!
[Edit: I’ve added the code for the extra gesture sequences you can perform if you wish to set up custom ones.]
blueprint:
name: Fibaro Swipe (Z-Wave JS)
description: 'Create automations for Swipe by Fibaro using the Z-Wave JS integration.'
domain: automation
input:
fibaro_swipe:
description: List of available Swipe devices.
selector:
device:
integration: zwave_js
manufacturer: Fibargroup
model: FGGC001
swipe_up:
description: Action to run when swiped up.
default: []
selector:
action: {}
swipe_down:
description: Action to run when swiped down.
default: []
selector:
action: {}
swipe_left:
description: Action to run when swiped left.
default: []
selector:
action: {}
swipe_right:
description: Action to run when swiped right.
default: []
selector:
action: {}
sequence_1:
description: Action to run when sequence 1 is performed
default: []
selector:
action: {}
sequence_2:
description: Action to run when sequence 2 is performed
default: []
selector:
action: {}
sequence_3:
description: Action to run when sequence 3 is performed
default: []
selector:
action: {}
sequence_4:
description: Action to run when sequence 4 is performed
default: []
selector:
action: {}
sequence_5:
description: Action to run when sequence 5 is performed
default: []
selector:
action: {}
sequence_6:
description: Action to run when sequence 6 is performed
default: []
selector:
action: {}
mode: single
max_exceeded: silent
variables:
device_id: !input 'fibaro_swipe'
- platform: event
event_type: zwave_js_value_notification
condition: '{{ trigger.event.data.device_id == device_id }}'
- variables:
property_key_name: '{{ trigger.event.data.property_key_name }}'
property_name: '{{ trigger.event.data.property_name }}'
label: '{{ trigger.event.data.label }}'
command_class_name: '{{ trigger.event.data.command_class_name }}'
value: '{{ trigger.event.data.value }}'
node_id: '{{ trigger.event.data.node_id }}'
- service: logbook.log
message: 'received event from Fibaro Swipe - Node {{node_id}}: {{ command_class_name }} - {{
value }} - {{ label }}'
- choose:
- conditions: "{{ property_name == 'scene' \n and property_key_name == '001'\n\
\ and value == 'KeyPressed' }}\n"
sequence: !input 'swipe_up'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '002'\n\
\ and value == 'KeyPressed' \n}}\n"
sequence: !input 'swipe_down'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '003'\n\
sequence: !input 'swipe_left'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '004'\n\
sequence: !input 'swipe_right'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '007'\n\
sequence: !input 'sequence_1'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '008'\n\
sequence: !input 'sequence_2'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '009'\n\
sequence: !input 'sequence_3'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '010'\n\
sequence: !input 'sequence_4'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '011'\n\
sequence: !input 'sequence_5'
- conditions: "{{ property_name == 'scene' \n and property_key_name == '012'\n\
sequence: !input 'sequence_6'
It’s also available here: Fibaro Swipe Blueprint
