Controls on-off, color, scenes, dimming, endpoint groups.
happy to hear your feedback, first post ![]()
Thank you so much for sharing this Blueprint.
I tried it with my iIuminize ZG2819S-CCT (not the ZG2819S-RGBW). It did not worked automatically because of the selector. After editing the selector to match my model it worked finally (not all keys, but I am happy
Thank you another time, I suggest you to edit the selector as well to get at least those two models.
let me know what selector info you needed to put in, as well as which keys don’t work. if you can give me the codes they send i can add it
I was looking for this exact blueprint for my remote control. But I use zigbee2mqtt. How do I need to adjust your blueprint for this to work?
Looking at the Z2M docs it seems like a (simpler) cousin of the ZG2868 for which I built a mostly working z2m blueprint here: Z2M: Paulmann Gent 2 RGB Remote
Lacking the device, I can’t verify but I presume you could get away mostly with deleting stuff (e.g., scene 4 to 7)
Hey, I have an identical remote but its branded “sunricher”. So I’ve made some adjustments to your great blueprint. Check the pull request.
Figured out why the color selection felt somewhat limited ![]()
@djoek sorry for asking but can I use thie ZG2819S-RGBW to control any light available in Home Assistant? I have a bunch of Hue Lamps and Bulbs i want to control it with.
Thank you very much!
You provided me with the jumping off point to get the ww/cw version to work.
It has quite a bit less functionality so even i could manage ![]()
Here are the changes:
remote:
description: iluminize 511.324 remote to use
selector:
device:
integration: zha
manufacturer: iluminize
model: ZG2819S-CCT
multiple: false
