Hi everyone!
I’m excited to share a blueprint I’ve created for the LK FUGA Wiser Wireless Battery 4-Button Switch (550D6001). This blueprint is designed for Zigbee2MQTT and allows you to configure actions for each button on the switch. It’s simple, efficient, and helps you get the most out of your device.
Blueprint Details
- Name: Action Handler for Wiser Wireless Battery 4-Button Switch
- Author: Preben Madsen (Probez)
- Version: 2024.21.12
- Import:
Supported Features
The blueprint provides the following controls for your switch:
- Top Button:
- Short press: Power On / Off
- Long press: Adjust dimmer/blinds Up / Down
- Bottom Button:
Note: Long press actions do not currently trigger a release event.
Configuration
- Supports Schneider Electric 545D6514 switches (Device Info).
- Each button action can be customized using the inputs in Home Assistant.
How to Use It
- Import the blueprint
- Import the YAML file into Home Assistant.
- Select your switch, configure the actions for each button, and you’re good to go!
Feel free to modify or extend this blueprint to fit your needs. If you run into issues or have suggestions for improvement, let me know!
Looking forward to hearing your feedback. Let’s make automation even smarter!
Cheers,
