I am trying to build more functionalitites in a blueprint, but I am struggling with two approaches.
- the variable thing:
Code:
domain: automation
input:
heating:
description: The climate device to use.
selector:
entity:
domain: climate
temp_sensor:
description: Temperature Sensor to check.
selector:
entity:
domain: sensor
device_class: temperature
window_sensor_1:
name: Door or Window Sensor
description: Check if window or door is open
selector:
entity:
domain: binary_sensor
device_class: opening
- choose:
- service: climate.set_temperature
entity_id: !input 'heating'
hvac_mode: >-
{% if states('WHAT TO PUT IN HERE TO USE window_sensor_1') == 'on' %} off
{% else %} heat
{% endif %}
temperature: '{{ set_temp }}'
- Option with action choose.
Code:
blueprint:
name: Heating Control and Window Sensor
description: Control your heating with options for group home, if temp is below
a specific value, set temp, and heating between specific times.
domain: automation
input:
heating:
selector:
entity:
domain: climate
temp_sensor:
selector:
entity:
domain: sensor
window_sensor_1:
selector:
entity:
groupname:
description: The group of people that have to be home.
default: []
selector:
entity:
domain: group
group_presence:
description: Heat only if Person of Group was present in a given amount of time
default: 07:30:00
selector:
time: {}
min_temp:
description: If temperature is below this value and someone is home, It turns
heating on.
default: 15
selector:
number:
min: 11.0
max: 25.0
step: 0.1
mode: slider
set_temp:
description: If the heating turns on, It heats to this target temperature.
default: 20
selector:
number:
min: 14.0
max: 25.0
step: 0.1
mode: slider
energy_temp:
name: Energy Saving Temperature
description: When away, keep the Energy Saving Temperature
default: 17
selector:
number:
min: 14.0
max: 25.0
step: 0.1
mode: slider
time_after:
description: After this time the heating turns on, so it's warm in the morning
default: 07:30:00
selector:
time: {}
time_before:
description: After this time the heating turns off, This to prevent the heating
is on in the middle of the night
default: '21:30:00'
selector:
time: {}
source_url: https://gist.github.com/f45tb00t/eab416909ff6d125d7f3c6170ab017a9
variables:
set_temp: !input 'set_temp'
energy_temp: !input 'energy_temp'
- platform: homeassistant
event: start
- platform: event
event_type: automation_reloaded
- platform: time_pattern
minutes: /1
- choose:
- conditions:
- condition: state
entity_id: !input 'window_sensor_1'
state: on
sequence:
hvac_mode: off
- conditions:
- condition: numeric_state
entity_id: !input 'temp_sensor'
below: !input 'min_temp'
- condition: time
before: !input 'time_before'
after: !input 'time_after'
- condition: not
conditions:
- condition: state
entity_id: !input 'groupname'
for: !input 'group_presence'
state: not_home
sequence:
- service: climate.set_preset_mode
preset_mode: none
hvac_mode: heat
default:
preset_mode: Energy heat
temperature: '{{ energy_temp }}'
mode: single
Weird is, that I can add an automation, but the automation is not visible within the automation menue, but can be found in automation.yaml
The error I get is:
2021-09-01 11:31:21 ERROR (MainThread) [homeassistant.components.automation] Blueprint Heating Control and Window Sensor generated invalid automation with inputs OrderedDict([(‘heating’, ‘climate.heizung_wohnzimmer’), (‘temp_sensor’, ‘sensor.lumi_lumi_weather_temperature_wohnzimmer’), (‘window_sensor_1’, ‘binary_sensor.lumi_lumi_sensor_magnet_aq2_acd2e401_on_off_wohnzimmer_velux’), (‘groupname’, ‘group.awesome_people’)]): expected str for dictionary value @ data[‘action’][0][‘choose’][0][‘conditions’][0][‘state’]. Got None
It would be great if anyone has an idea how to fix option 1 or 2.
Cheers
FB
