I am facing problem when I try to build an automation using the Blueprint(Attached) I have created.
I can see following error in HA log section.
When I prepare the automation using blank GUI mechanism, my concept works fine
blueprint:
name: Electricity Saver for Rooms having No Natural Light
description: This blueprint will automate closed areas where there is no natural light throghout the day(Wash Rooms, Under Ground Rooms etc)
Turn on respective lights when area is occupied(motion detected) and will turn off the lights when area is unoccupied(No Motion Detected).
Also, one an control the lights using switches and light operation(specially) using switches has also been taken cared
domain: automation
source_url:
input:
motion_entity:
selector:
entity:
domain: binary_sensor
device_class: motion
light_target:
selector:
entity:
domain: light
mode: restart
max_exceeded: silent
platform: state
entity_id: !input motion_entity
to: 'off'
platform: state
entity_id: !input light_target
to: 'on'
platform: time_pattern
seconds: '1'
- choose:
- conditions:
- condition: state
entity_id: motion_entity
state: 'on'
sequence:
- service: light.turn_on
entity_id: light_target
- conditions:
- condition: state
state: 'off'
sequence:
- service: light.turn_off
mode: restart
platform: state
to: 'off'
platform: state
to: 'on'
seconds: '1'
The Automation Generated using UI is as follows:
alias: EnergySave
description: ''
- platform: state
entity_id: binary_sensor.ewelink_ms01_29c00825_ias_zone
to: 'off'
- platform: state
to: 'on'
- platform: time_pattern
seconds: '1'
condition: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
device_id: 5b588b838ae416795f967d7be7dca0a2
entity_id: light.veea_light_inc_light_001_ddfbe2fe_level_on_off
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: restart'
The Error Generated in logs are as follows:
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:628
Integration: Automation ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: June 23, 2022 at 7:35:39 PM (136 occurrences)
Last logged: 9:44:24 AM
* Blueprint Electricity Saver for Rooms having No Natural Light generated invalid automation with inputs OrderedDict([('motion_entity', OrderedDict([('device_id', '3f411e986a1b662ddbdbef5263f69a61'), ('entity_id', 'binary_sensor.ewelink_ms01_29c00825_ias_zone')])), ('light_target', OrderedDict([('device_id', '5b588b838ae416795f967d7be7dca0a2'), ('entity_id', 'light.veea_light_inc_light_001_ddfbe2fe_level_on_off')]))]): Entity ID device_id is an invalid entity ID for dictionary value @ data['action'][0]['choose'][0]['conditions'][0]['entity_id']. Got None not a valid value for dictionary value @ data['action'][0]['choose'][0]['sequence'][0]['target']['entity_id']. Got None
* Blueprint Electricity Saver for Rooms having No Natural Light generated invalid automation with inputs OrderedDict([('motion_entity', 'binary_sensor.ewelink_ms01_29c00825_ias_zone'), ('light_target', OrderedDict([('device_id', '5b588b838ae416795f967d7be7dca0a2'), ('entity_id', 'light.veea_light_inc_light_001_ddfbe2fe_level_on_off')]))]): extra keys not allowed @ data['action'][0]['conditions']. Got None extra keys not allowed @ data['action'][0]['sequence']. Got None
* Blueprint Electricity Saver for Rooms having No Natural Light generated invalid automation with inputs OrderedDict([('motion_entity', OrderedDict([('device_id', '3f411e986a1b662ddbdbef5263f69a61'), ('entity_id', 'binary_sensor.ewelink_ms01_29c00825_ias_zone')])), ('light_target', OrderedDict([('device_id', '5b588b838ae416795f967d7be7dca0a2'), ('entity_id', 'light.veea_light_inc_light_001_ddfbe2fe_level_on_off')]))]): extra keys not allowed @ data['action'][0]['conditions']. Got None extra keys not allowed @ data['action'][0]['sequence']. Got None
* Blueprint Electricity Saver for Rooms having No Natural Light generated invalid automation with inputs OrderedDict([('motion_entity', 'binary_sensor.ewelink_ms01_29c00825_ias_zone'), ('light_target', OrderedDict([('device_id', '5b588b838ae416795f967d7be7dca0a2'), ('entity_id', 'light.veea_light_inc_light_001_ddfbe2fe_level_on_off')]))]): not a valid value for dictionary value @ data['action'][0]['target']['entity_id']. Got None
* Blueprint Electricity Saver for Rooms having No Natural Light generated invalid automation with inputs OrderedDict([('motion_entity', OrderedDict([('device_id', '3f411e986a1b662ddbdbef5263f69a61'), ('entity_id', 'binary_sensor.ewelink_ms01_29c00825_ias_zone')])), ('light_target', OrderedDict([('device_id', '5b588b838ae416795f967d7be7dca0a2'), ('entity_id', 'light.veea_light_inc_light_001_ddfbe2fe_level_on_off')]))]): not a valid value for dictionary value @ data['action'][0]['target']['entity_id']. Got None
It will be great if someone can direct me to exact root cause.
Thanks in advance !!!
