Blueprint: Message Malformed
Hi there,
Very new to YAML and home assistant in general, so please bear with me.
I’m trying to execute a choose command in a blueprint with condition:
# reset helpers when switch turns off
  - choose:
      - conditions:
          - condition: >
              {{target_switch.trigger.to_state.state == "off"}}
target_switch is defined as follows:
input:
    motion_sensor:
      description: link to motion sensor
      selector:
        entity:
          filter:
            - domain: binary_sensor
            - device_class: motion
    target_switch:
      description: link to switch to be used
      selector:
          entity:
            - domain: switch
When i try to make an automation based on this blueprint, i get the following error:
"Message malformed: Unexpected value for condition: '{{target_switch.trigger.to_state.state == "off"}} '. Expected and, device, not, numeric_state, or, state, sun, template, time, trigger, zone @ data['actions'][0]['choose'][0]['conditions'][0]"
what am i doing wrong?
Thanks in advance for anyone taking a look at this!
Full code for context:
blueprint:
  name: Motion Light Tutorial
  description: Turn a light on based on detected motion
  domain: automation
  homeassistant:
    min_version: 2024.6.0
  input:
    motion_sensor:
      selector:
        entity:
          filter:
    target_switch:
      selector:
          entity:
            - domain: switch
    helper_man:
      description: Boolean helper to determine manual operation
      selector:
        entity:
          filter:
            - domain: input_boolean
    helper_auto:
      name: Helper Automatic
      description: Boolean helper to determine automatic operation
      selector:
        entity:
          filter:
triggers:
  - trigger: state
    entity_id: !input motion_sensor
  - trigger: state
    entity_id: !input target_switch
  - trigger: state
    to: "off"
    for:
      seconds: 30
      minutes: 0
actions:
  - choose:
      - conditions:
          - condition: >
        sequence:
          - action: input_boolean.turn_off
              entity_id: !input helper_auto
              entity_id: !input helper_man
  # when motion gets triggered and no manual override
  - choose:
      - conditions:
          - condition: >
              {{motion_sensor.trigger.to_state.state == "on" & helper_man == "off"}}
        sequence:
          - action: input_boolean.turn_on
          - action: switch.turn_on
  # when no motion and no manual override
  - choose:
      - conditions:
          - condition: >
              {{motion_sensor.trigger.to_state.state == "off" & helper_man == "off"}}
        sequence:
          - action: switch.turn_off
  # when switch is set to on manually, turn on override
  - choose:
      - conditions:
          - condition: >
              {{target_switch.trigger.to_state.state == "on" & helper_auto == "off"}}
        sequence:
  #if 30 minutes has passed (third trigger), turn off manual override and turn off switch
  - choose:
      - conditions:
          - condition: >
              {{target_switch == "on" & helper_man == "on"}}
        sequence:
Please format the blueprint like you did with these sections
I’m trying :smiley: didn’t find the preview button for the post so trying to fix it live
Hello bram.rondele,
There is always only 1 trigger, so the ‘target_switch.’ part is invalid.
Also the way to display code here is the </> button in the editor toolbar.
Okay, only one trigger makes sense. But there are 3 triggers defined. Of which 2 can be triggered when changing to on or off. So then how do I differentiate which trigger triggered the blueprint?
trigger_id
Thank you very much. This was indeed the piece i was missing.
If one of the suggestions listed solves your problem, please consider clicking the solution button to close the thread. (even your own…)
