2020-12-22 21:41:05 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Failed to load blueprint: Unable to find mute_spotify_ads.yaml (See /config/configuration.yaml, line 55).
@GrumpyMeow is it possible to update the description with a button from this integration ? it’s about something like that because I don’t know how to implement it
The original author forgot to change the source URL to their own GitHub repo or gist. The source URL is only used for updating blueprints when the original changes.
Sorry, not to be blunt but several users have reported the same issue of getting the following error message:
No valid blueprint found in the topic. Blueprint syntax blocks need to be marked as YAML or no syntax.
I’m just asking if someone more knowledgeable could write down a few steps how to paste this YAML into blueprints. I can find where to switch to YAML editing in Automations, but I’m kinda lost with blueprints unfortunately. Sorry if this is something basic, I am a relatively new HA user.
Wait. There’s actually an error for me too. @grumpymeow maybe you should remove the second code block? Anyway, you can always copy it, and make a new file in /config/blueprints/automations/mute_spotify_ads.yaml.
Yes, that’s what I was talking about. But judging by the thread activity the OP isn’t really going to fix this anytime soon, hence my request for some help in ‘manual’ installation.
Anyway, you can always copy it, and make a new file in /config/blueprints/automations/mute_spotify_ads.yaml .
And this is exactly what I was looking for Thank you!
