pepite
February 9, 2021, 2:45pm
1
Hello Everybody,
I try to create my first blueprint for control my radiators.
One in with climate and other with light (qubino)
I put in input this :
input:
climate_target:
description: xxxxxxxxxxxxxxxxxxxxx
selector:
entity:
domain: climate
is_fil_pilote:
description: xxxxxxxxxxxxxxxxxxxxxxx
default: false
selector:
boolean:
# heater qubino
heater_wire:
selector:
entity:
domain: light
Then for me the input climate_target is optional if i toggle is_fil_pilote and choose the input heater_wire.
But when i want to save my automation depending of this blueprint, i have this error :
Missing imput climate_target
But i dont need it in the case i choose a qubino heater.
Is anybody has an idea to workaround please?
I found with an input like this
input:
climate_target:
default: climate.default
But i m not sure that the great solution.
kellerza
(Johann Kellerman)
February 22, 2021, 8:58pm
2
The default can be an empty dict:
default: {}
I used this for a light. The choose ensure you only call the service if it’s not empty/None
blueprint:
input:
light_target:
default: {}
selector:
entity:
domain: light
variables:
light_target: !input light_target
- choose:
- conditions: "{{ light_target }}"
sequence:
- service: homeassistant.turn_off
Tarcisio
(Tarcisio Alves de Menezes)
February 2, 2022, 5:37am
3
That didn’t work for me!
Do you guys know what’s wrong with my blueprint?
kellerza
(Johann Kellerman)
February 2, 2022, 6:05am
4
Are you sure you need the wait_for_trigger? It might already be off by the time the script runs? (It all async and NOT guaranteed to run immediately)
Tarcisio
February 2, 2022, 9:19am
5
The light will turn off just after the wait_for_trigger. That’s part is okey. The problem are the conditions
- conditions: "{{ switch_target }}"
Doesn’t work.
Tarcisio
February 2, 2022, 1:07pm
6
Ok. Just found the solution.
Doesn’t work because condititions is wating for true or false. the template "{{ light_target }}" renders a dictionary (empty if the entity is not selected).
- conditions: "{{ light_target|length > 0 }}" does the trick in this case.
That’s a working blueprint that turns the light(s) ON whenever motion is detected.
blueprint:
name: Motion Light ON (revisado)
description: Turn light(s) ON when motion is detected and OFF when there is no motion.
domain: automation
input:
motion_entity:
selector:
entity:
domain: binary_sensor
device_class: motion
switch_target:
default: {}
selector:
entity:
domain: switch
light_target:
default: {}
selector:
entity:
domain: light
no_motion_wait:
description: "Time to leave the light on after motion sensor changes to 'clear' (off)."
default: 30
selector:
number:
min: 0
max: 3600
unit_of_measurement: seconds
# If motion is detected while automation is running, script will restart.
mode: restart
platform: state
entity_id: !input motion_entity
to: "on"
variables:
switch_target: !input switch_target
- choose:
- conditions: "{{ light_target|length > 0 and switch_target|length > 0 }}"
sequence:
- service: switch.turn_on
- service: light.turn_on
- wait_for_trigger:
- platform: state
to: 'off'
- delay: !input no_motion_wait
- service: switch.turn_off
- service: light.turn_off
- conditions: "{{ switch_target|length > 0 }}"
sequence:
- wait_for_trigger:
- platform: state
to: 'off'
sequence:
- wait_for_trigger:
- platform: state
to: 'off'
default: []
kellerza
(Johann Kellerman)
February 2, 2022, 1:44pm
7
Indeed, seems like it did not like the falsy value and what I did in the end seems to be a double not
- choose:
- conditions:
- "{{ not not light_target }}"
kellerza
(Johann Kellerman)
February 2, 2022, 1:47pm
8
For reference this was mine that backed off due to repeat movements:
blueprint:
name: Alarm Zone Automations
description: Translate a binary_sensor alarm zone to an input number value. Optionally switch lights
domain: automation
# source_url: https://github.com/home-assistant/core/blob/40c727df6663f6c6a9e6509e1771b3fe19acb079/homeassistant/components/automation/blueprints/motion_light.yaml
input:
motion_entity:
selector:
entity:
input_number_entity:
selector:
entity:
domain: input_number
light_target:
default: {}
selector:
entity:
domain: light
no_motion_t1:
description: Initial time.
default: 60
selector:
number:
min: 10
max: 300
no_motion_t2:
description: Second wait time.
default: 240
selector:
number:
min: 10
max: 300
boost_n:
description: "Boost to second interval if n moves in the first"
default: 2
selector:
number:
min: 0
max: 9
all_day:
name: Switch all day long
description: "Always switch on lights, even during the day"
default: 0
selector:
number:
min: 0
max: 1
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
variables:
no_motion_t1: !input no_motion_t1
no_motion_t2: !input no_motion_t2
input_number_entity: !input input_number_entity
boost_n: !input boost_n
all_day: !input all_day
platform: state
to: "on"
- choose:
- conditions: "{{ states(input_number_entity)|float < 0.1 }}"
sequence:
- service: input_number.set_value
entity_id: !input input_number_entity
value: 0.1
- choose:
- conditions:
# Switch on if night or if all_day=1
- "{{ not is_state('sun.sun', 'above_horizon') or all_day|int==1 }}"
# Only switch if we have a light
sequence:
# >3.n - n=1-9, n=count in last 60 seconds
- choose:
# Ensure we dont go past 3.9 when incrementing 0.1
- conditions: "{{ states(input_number_entity)|float > 3.8 }}"
sequence:
value: 3.9
# Add .1 increments to count the amount of triggers
- conditions: "{{ states(input_number_entity)|float > 2.95 }}"
sequence:
value: "{{ (states(input_number_entity)|float+0.1)|round(1) }}"
# increase from 2-->3, but keep the minor...
- conditions: "{{ states(input_number_entity)|float > 1.95 }}"
sequence:
value: "{{ (states(input_number_entity)|float+1)|round(1) }}"
# - repeat:
# count: 10
# sequence:
# - service: input_number.increment
# data:
# entity_id: !input input_number_entity
# ELSE set to 3 - starting here...
default:
value: 3
- delay:
seconds: "{{ no_motion_t1 }}"
# decrement by 1 (10xstep)
# 2..2.9 = no_motion_t1 < t < no_motion_t2
# - repeat:
# count: 10
# sequence:
# - service: input_number.decrement
# data:
value: "{{ (states(input_number_entity)|float-1)|round(1)|float }}"
# if more than boost_n times, activate the boost "on" time
- variables:
boost_active: "{{ states(input_number_entity)|float > (2.05+(boost_n|int)/10) }}"
# Switch light off if boost_NOT_active
- choose:
- conditions:
- "{{ not boost_active }}"
sequence:
- delay:
seconds: "{{ no_motion_t2 }}"
# Switch light off after delay if boost_active
- choose:
- conditions:
- "{{ boost_active }}"
sequence:
# 5min < 15min
value: 1
- delay:
minutes: "10"
# 15min < t < 30min
value: 0.5
- delay:
minutes: "15"
# 30min < t < 45min
value: 0.2
- delay:
minutes: "15"
# 45min < t < 60min
value: 0.1
- delay:
minutes: "15"
# >60 min
value: 0
It’s the middle of the day, so lots of movement but this is the result of the input_numbers for each zone.
