Hi.
I am trying to create a blueprint that can dim an Aqara Opple switch using ZHA events.
When holding a button, it sends 1 “Hold” event and upon release, a “release” event.
My current configuration does not work, since i cannot figure out the until condition. The current code does not work, since the template condition doesnt work with events.
Any ideas on how to make this work? Small example pasted below.
Help would be greatly appreciated.
blueprint:
name: TEST - Opple2
description: Control and dim lights with Aqara Opple switch 3 bands (WXCJKG13LM)
domain: automation
input:
aqara_sw:
description: Aqara switch to use
selector:
device:
integration: zha
manufacturer: LUMI
light_top:
description: The light to control with the top buttons
default: []
selector:
entity:
domain: light
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input "aqara_sw"
- variables:
command: "{{ trigger.event.data.command }}"
- choose:
## Turn on upper lights
- conditions:
- "{{ command == '1_single' }}"
sequence:
- service: light.turn_on
target: !input "light_top"
## Increase brightness for upper lights
- conditions:
- "{{ command == '1_hold' }}"
sequence:
repeat:
sequence:
transition: 0.5
brightness_step_pct: 10
until:
- condition: template
value_template: "{{ command == '1_release' }}"
