Hard to have comunity shared blueprint for this, because HA doesn’t have “preinstalled” mode selector, so everyone does this on their own.
I have input_select.mode with values Day, Evening, Night, Away and Holiday. Then, when you want to turn on light by motion for example, instead of calling light.turn_on, I call following script. Most zigbee lights I found can’t be pre-configured to certaing brightness without turing them on, and also you’ll find different dimmers have different lower value. For example the lowest value for one of my lights is 15%, while another has 10%. And that means you end up with different setting for each light anyway.
alias: Set Light Per Mode
fields:
light:
selector:
entity:
domain: light
required: true
day:
selector:
number:
min: 0
max: 100
step: 1
unit_of_measurement: "%"
mode: slider
default: 0
evening:
selector:
number:
min: 0
max: 100
step: 1
mode: slider
default: 100
night:
selector:
number:
min: 0
max: 100
step: 1
mode: slider
default: 20
sequence:
- condition: template
value_template: >-
{{ (is_state('input_select.mode', 'Night') and night > 0) or
(is_state('input_select.mode', 'Evening') and evening > 0) or
(is_state('input_select.mode', 'Day') and day > 0) }}
- service: light.turn_on
data_template:
entity_id: "{{ light }}"
brightness_pct: >-
{% if is_state('input_select.mode', 'Night') %} {{ night }} {% elif
is_state('input_select.mode', 'Evening') %} {{ evening }} {% else %} {{
day }} {% endif %}
mode: single
icon: mdi:brightness-6
