A simple blueprint to clear notifications that are “stuck” on android from when the automation stops for some reason.
blueprint:
description: "Clears notifications that gets stuck when the automations failed. \n
This automation is default set to only be able to run when no other automations are
currently running as the idea of this blueprint is to clear the 'stuck' notifications. \n
But you have the option to add automations that you want to be able to run alongside this
one under the exclude parameter."
domain: automation
input:
device:
description: Pick the device that you want to clear notifications on
selector:
device:
integration: mobile_app
exclude:
name: Excluded Automations
description: "Automations that you want to be allowed to run when you send the clear.\nOnly
entities are supported, devices must be expanded!"
default:
entity_id: []
selector:
entity:
domain: automation
action_1:
description: Do something before the notification is cleared, like turn on/off a bool, wait for a script to execute.
selector:
action: {}
default: []
action_2:
description: Do something after the notification is cleared, like turn off/on a bool.
selector:
action: {}
default: []
variables:
exclude: !input exclude
# Triggers
- platform: event
event_type: mobile_app_notification_action
condition:
- condition: template
value_template: >-
{% set automation = namespace(runs=[]) %} {% for automations in states.automation
| selectattr("attributes.current", "defined")
| selectattr('attributes.current', '!=', '0')%}
{% if 0 <= automations.attributes.current and not automations.entity_id in exclude.entity_id %}
{% set automation.runs = automation.runs + [automations.attributes.current] %}
{%endif%}
{% endfor %}
{{automation.runs | sum == 0}}
- choose: []
default: !input action_1
- device_id: !input device
domain: mobile_app
type: notify
message: clear_notification
tag: "{{trigger.event.data['tag']}}"
- choose: []
default: !input action_2
mode: restart
