Blueprint to fetch Calender Events for AI based Assistant Integration
:spiral_calendar: Home Assistant Community – Blueprint: Fetch Calendar Events
Hi everyone,
I’d like to share a small but useful blueprint I created:
:point_right: Fetch Calendar Events Blueprint
:dart: Why I built this
The standard way of exposing calendar entities to Assistants in Home Assistant is often limited:
  • It only works in some setups,
  • and it usually returns events for a very short time interval only.
This made it difficult to ask an assistant things like:
“Show me all badminton events for this October”
So I decided to create a blueprint that queries any number of calendars for an arbitrary date range, and returns all events in a structured format that Assistants (or LLMs) can use.
:rocket: Features
  • Query multiple calendars at once
  • Define your own time span (start_of_period, end_of_period)
  • Returns a structured dictionary with all events, including:
    • calendar source
    • start & end
    • summary
    • location (if available)
:robot: How to use with Assistants
  1. Import the blueprint:
    1.1 via this link: Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
    Or
    1.2 manually with this github url:
    https://github.com/lweberru/LLMCalender/blob/main/LLMCalender.yaml
  2. Create a script from it, select your calendars and time range.
  3. In the script’s settings, enable Expose to Assistants.
  4. Now you can ask your assistant things like:
:memo: Closing
This blueprint makes calendar queries much more flexible and assistant-friendly.
I’d be happy to hear your feedback, suggestions, or improvements!
:sparkles: Enjoy!
Hello Lukas,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
