Hi, I’m trying to write a small blueprint which shall trigger an action, when entities of device_class: problem
and integration: shelly
turning on.
I have created a sensors
variable at fill it with the help of some Jinja2 code. At the end it shall provide a string return, containing all friendly_names
of Shelly problem entities which are turned on.
In the automation I want to send notifications, which shall include the content of the sensors
variable. For whatever reason, within the action the sensors
variable contains the correct amount of entities turned on, but instead of the friendly_name
they are always printed as None
When I execute the Jinja2 code with the help of the Developer Tools, then the return is like I want to have it: A string with comma separated friendly_names
of the affected entities
I already have two other blueprints with similar code and they work fine. Major difference between them is, that the one which is not working, uses platform: state
as trigger.
I’m pretty sure, that I have a mistake somewhere, or even worse, I misunderstand some concept/workflow of blueprints…
Any idea would be helpful and appreciated.
Here the code of the blueprint:
blueprint:
name: Detection of Shelly senors for overheating, overpowering and overvoltage
description: Monitors the Shelly sensors for overheating, overpowering and overvoltage as trigger for user defined actions
domain: automation
input:
shelly_entities:
name: The Shelly entity to check for problems
description: The Shelly problem entities will trigger the action
selector:
entity:
multiple: true
filter:
integration: shelly
exclude:
description: Shelly entities to exclude from detection. Only entities are supported, devices must be expanded!
default:
entity_id: []
selector:
entity:
- device_class:
- problem
# user_conditions:
# name: (Optional) Additional Condition(s)
# description: In case of additional conditions must be met, they can be defined here
# selector:
# condition:
actions:
description: Notifications or similar to be run. {{sensors}} is replaced with the names of sensors having problems.
selector:
action: {}
variables:
exclude: !input exclude
sensors: >
{% set result = namespace(sensors=[]) %}
{% set all_shelly_device_ids = integration_entities('shelly') | map('device_id') | unique | list %}
{%- for shelly_device_id in all_shelly_device_ids %}
{% set shelly_entity_list = device_entities(shelly_device_id) %}
{%- for shelly_entity in shelly_entity_list %}
{% if not shelly_entity in exclude.entity_id %}
{%- if is_state_attr(shelly_entity, 'device_class', 'problem') and is_state(shelly_entity, 'on') %}
{% set result.sensors = result.sensors + [state_attr(shelly_entity, 'name')] %}
{%- endif %}
{%- endif %}
{%- endfor %}
{%- endfor %}
{{ result.sensors | join(', ') }}
- platform: state
entity_id: !input shelly_entities
to: 'on'
#condition:
#- and
# - '{{ sensors != '''' }}'
# - !input user_conditions
- choose: []
default: !input actions
mode: single
And here the defined action when I configure the blueprint:
service: notify.persistent_notification
metadata: {}
message: >
Schwerwiegende Probleme mit den folgenden Shelly Geräten entdeckt:
{{sensors}}
title: Schwerwiegende Probleme mit Shelly Geräten entdeckt
