I’m confused as to why this trigger in a blueprint doesn’t work
blueprint:
#....elided description
input:
timeout_minutes:
name: Motion timeout input
description:
An input_number to configure the time after no motion when lights will turn off.
Create a helper for this or add an input_number to your configuration.yaml.
selector:
entity:
domain: input_number
variables:
timeout_minutes: !input "timeout_minutes"
# trigger when motion stops for the number of minutes specified by input_timeout
- platform: state
entity_id: !input motion_entity
to: "off"
for:
minutes: >-
{{ states(timeout_minutes) | int }}
action: ....
This crashes when triggered with
Template variable error: 'timeout_minutes' is undefined when rendering '{{ states(timeout_minutes) | int }}'
The variable is clearly defined however. Is it not possible to use a blueprint variable in a template on a trigger? The docs aren’t clear about this or at least I couldn’t find any information. Thanks for any insight!
Unfortunately that doesn’t make a difference. The !input yaml extension works the same with or without quotes.
I think what’s going on here is that for whatever reason you aren’t allowed to use any variables in a template that’s part of a trigger. See here: Support variables in a Template Trigger
The value of the variable timeout_minutes is something like input_number.motion_lights_timeout_minutes – it’s the entity_id of the input holding the value, not the value itself. That’s why states( in a template is necessary.
I know I could use a number input directly on the blueprint but that doesn’t solve the case that I want which is to have the timeout be configurable at runtime. If it’s a number input on the blueprint then it can’t be changed at runtime.
You can however use them in wait_for_trigger actions for whatever reason, so this works:
blueprint:
input:
timeout_minutes:
description:
selector:
entity:
variables:
- platform: state
to: "on"
- service: light.turn_on
entity_id: !input "light_target"
- wait_for_trigger:
platform: state
to: "off"
for:
minutes: >-
Unfortunately this isn’t a solution I can use in my actual use case since it would conflict with other triggers I need to use in the same automation.
I mean, it’s not really the blueprint that’s the problem; automation triggers don’t support templates, universally. Just because your current understanding only allows trivial use-cases doesn’t signify a flaw in the tool itself
I think my edit to my above post still applies though: you can just use a number selector instead of forcing the use of an input_number. This would put a number in the input variable, instead of an entity ID, and allow the use of the input variable in the trigger, I believe, while uncomplicating the process.
It has been awhile since I messed with blueprints, sorry for my forgetfulness when it comes to the interactions of everything. Here’s hoping I didn’t forget something else about input variables
