I have red, green and blue lights in Home Assistant named light.r1, light.g1 and light.b1. I want to make a template light that presents these as one RGB light. I know how to do that, no problem.
However, I don’t just have one set of lights, I have many. For example, I also have light.r_back, light.g_back and light.b_back as well as light.bdrm_red, light.bdrm_green and light.bdrm_blue, etc.
What I really want to make is a template light that can be parameterized with the three lights it will control.
I see blueprints for automations and scripts. I also see passing in variables to scripts. If these can do the job then I can’t figure out how.
Copy paste solution makes changes quite difficult if you need to edit many entries. Instead of blueprint I generate lights.yaml config with Python script: example.
