Can someone explain me how the boolean selector should work? I understand it so I can add the possibility to make actions/conditions maybe possible to be chosen to be on or off. Or am I wrong? How can I use boolean.
Another question is, can I make conditions or condition options boolean?
The boolean is true or false and you can use this in your blueprint whereever usefull.
input:
boolean_offset:
name: Turn on offset for non working days (Optional)
description: Turn on offset for non working days in your country
default: false
selector:
boolean:
With this configuration the automation will run if the selector is “on” = true and not run if “off” = false
Not a really usefull case, but it shows how it works.
Also i did not try to use the boolean without a variable, maybe it is usable as condition without this.
Is it possible to change the boolean (created in a blueprint) as an action?
For instance, I could define a helper boolean in my blueprint, for example ‘boolean_error’, and check that boolean as part of a condition an my actual automation.
Long story short, I’d like a way to automatically configure helpers so that if I reuse a blueprint 10 times, I don’t have to create 10 helpers.
