I installed several Blueprints, but none of them send the requested notifications. Notification services DO work normal in my own automations. Anyone an idea what can be wrong?
Give us an example for heaven’s sake?
Which blueprint?
What automation did you make out of the blueprint?
I also found that this wasn’t working with the Zone Notification blueprint (homeassistant/notify_leaving_zone.yaml). If I manually executed the resultant automation it notified, but when I actually left the zone it didn’t.
You have not answered my question. Shall I repeat it?
Calm down, I’m not behind my pc 24/7. Think I’m even in another time zone as well. The good thing about this kind of platform is that you can answer when you have time. Else it would be better to do live chat.
It’s about the ‘Battery level notification’ and ‘Entity unavailable notification’
Tried with empty message field, which should give a default message, as well as with a modified message.
In my case even manual execution doesn’t work.
My apologies I thought the 1st response was from you. anyway, no one is going to diagnose without the info
I mentioned two blueprints. Non of my notifiers work with it. iPhone, Whatsapp, Telegram, whatever.
Don’t know what more information I can give.
Links to those blueprints…
Error logs…
Hope this helps
2020-12-16 16:15:18 ERROR (MainThread) [homeassistant.components.automation.battery_level_notification] Error rendering variables: UndefinedError: ‘trigger’ is undefined
You get that when you manually execute automations that use the trigger
context in the action, that is expected.
You should rather modify the state of the entity it listens to under /developer-tools/states
Thanks. That seems to work. Never experienced anything like this in other automations.
Solved
This is the automation that was made from the blueprint:
- id: '1608108681796'
alias: Zone Notification test
description: ''
use_blueprint:
path: homeassistant/notify_leaving_zone.yaml
input:
person_entity: person.jacqui
zone_entity: zone.home
notify_device: 7a19d15b040a11eb96ed4feaa5f55cff
There’s nothing in the error logs - it doesn’t look like it triggered, yet person.jacqui’s state went from home to not_home.
I don’t know what blueprint this is for, but I suspect that the problem here is using a ‘notify device’ rather than a notify service.
This is one of the two blueprints that shipped with core 2020.12.0.
Can you paste it?
blueprint:
name: Zone Notification
description: Send a notification to a device when a person leaves a specific zone.
domain: automation
source_url: https://github.com/home-assistant/core/blob/295b1a91c3017258b2743f951e2d2bdb2a5690da/homeassistant/components/automation/blueprints/notify_leaving_zone.yaml
input:
person_entity:
selector:
entity:
domain: person
zone_entity:
selector:
entity:
domain: zone
notify_device:
name: Device to notify
description: Device needs to run the official Home Assistant app to receive notifications.
selector:
device:
integration: mobile_app
platform: state
entity_id: !input person_entity
variables:
zone_entity: !input zone_entity
# This is the state of the person when it's in this zone.
zone_state: "{{ states[zone_entity].name }}"
person_entity: !input person_entity
person_name: "{{ states[person_entity].name }}"
condition:
condition: template
value_template: "{{ trigger.from_state.state == zone_state and trigger.to_state.state != zone_state }}"
domain: mobile_app
type: notify
device_id: !input notify_device
message: "{{ person_name }} has left {{ zone_state }}"
I still haven’t quite got my head around the selectors, but try changing the blueprint to this…
blueprint:
domain: automation
input:
person_entity:
selector:
entity:
domain: person
zone_entity:
selector:
entity:
domain: zone
notify_device:
selector:
service:
domain: notify
platform: state
variables:
condition:
condition: template
service: !input notify_device
… and the automation to this…
description: ''
use_blueprint:
input:
notify_device: YOUR NOTIFY SERVICE ( notify.mobile_app_pixel_4 or whatever)
Reload automations, see if any errors, if not trigger it (not manually, with an actual state change) and see if it works.
If it does, see if you get the correct selectors in the ui for creating an automation from the modified blueprint.
Thanks, I’ll give that a go when I have the opportunity.
My real point here is that one of the two blueprints that shipped with 2020-12.0 doesn’t seem to be working as expected.
I have the same issue, but it seems that this issue is only when you use zone.home. For every other zone notify_leaving_zone.yaml
and notify_entering_zone.yaml
the templates are working.
