Bluetooth adapter is not recognized in Home Assistant Core
Hello everyone,
i need support with my hardware. My Bluetooth adapter is not recognized correctly in Home Assistant. I see the following messages in the logs.
Home Assistant Core Protocol:
2024-09-13 13:44:29.024 ERROR (MainThread) [bluetooth_auto_recovery.recover] Unexpected error while attempting USB reset of hci0: [Errno 19] No such device
  File "/usr/local/lib/python3.12/site-packages/bluetooth_auto_recovery/recover.py", line 515, in _usb_reset_adapter
    return await dev.async_reset()
  File "/usr/local/lib/python3.12/site-packages/usb_devices/__init__.py", line 49, in async_reset
    return await asyncio.get_running_loop().run_in_executor(None, self.reset)
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.12/site-packages/usb_devices/__init__.py", line 56, in reset
    return self.usb_device.reset()
  File "/usr/local/lib/python3.12/site-packages/usb_devices/__init__.py", line 141, in reset
    return ioctl(usb_dev, USBDEVFS_RESET, 0) > -1
OSError: [Errno 19] No such device
2024-09-13 13:44:29.026 ERROR (MainThread) [habluetooth.scanner] hci0 (A8:43:A4:29:16:2D): Failed to restart Bluetooth scanner: hci0 (A8:43:A4:29:16:2D): Failed to start Bluetooth: adapter 'hci0' not found; Try power cycling the Bluetooth hardware.
  File "src/habluetooth/scanner.py", line 329, in habluetooth.scanner.HaScanner._async_start_attempt
  File "src/habluetooth/scanner.py", line 332, in habluetooth.scanner.HaScanner._async_start_attempt
  File "/usr/local/lib/python3.12/site-packages/bleak/__init__.py", line 203, in start
    await self._backend.start()
  File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/scanner.py", line 178, in start
    self._stop = await manager.passive_scan(
  File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/manager.py", line 513, in passive_scan
    self._check_adapter(adapter_path)
  File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/manager.py", line 209, in _check_adapter
    raise BleakError(f"adapter '{adapter_path.split('/')[-1]}' not found")
bleak.exc.BleakError: adapter 'hci0' not found
  File "src/habluetooth/scanner.py", line 528, in habluetooth.scanner.HaScanner._async_restart_scanner
  File "src/habluetooth/scanner.py", line 286, in _async_start
  File "src/habluetooth/scanner.py", line 373, in _async_start_attempt
habluetooth.scanner.ScannerStartError: hci0 (A8:43:A4:29:16:2D): Failed to start Bluetooth: adapter 'hci0' not found; Try power cycling the Bluetooth hardware.
2024-09-13 13:44:46.778 INFO (MainThread) [habluetooth.scanner] hci0 (A8:43:A4:29:16:2D): Bluetooth scanner has gone quiet for 90s, restarting
dmesg Protocol:
\[\e]0;\u@\h:\w\a\]\W $ dmesg| grep hci0
[321065.635034] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[321065.637003] Bluetooth: hci0: RTL: rom_version status=0 version=1
[321065.637016] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[321065.637625] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[321065.637734] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[321066.240397] Bluetooth: hci0: RTL: fw version 0x75b8f098
[342848.560991] Bluetooth: hci0: Opcode 0x200c failed: -71
[342848.561017] Bluetooth: hci0: Unable to disable scanning: -71
[342848.561514] Bluetooth: hci0: Opcode 0x200c failed: -71
[342848.561534] Bluetooth: hci0: Unable to disable scanning: -71
[342848.561549] Bluetooth: hci0: Unable to disable scanning: -71
[342848.562524] Bluetooth: hci0: Opcode 0x200c failed: -71
[342848.562545] Bluetooth: hci0: Unable to disable scanning: -71
[342848.562560] Bluetooth: hci0: stop background scanning failed: -71
[342859.012217] Bluetooth: hci0: Opcode 0x200c failed: -71
[342859.012238] Bluetooth: hci0: Unable to disable scanning: -71
[342859.012250] Bluetooth: hci0: Unable to disable scanning: -71
[342859.013269] Bluetooth: hci0: Opcode 0x200c failed: -71
[342859.013289] Bluetooth: hci0: Unable to disable scanning: -71
[342859.013305] Bluetooth: hci0: stop background scanning failed: -71
[342869.002932] Bluetooth: hci0: Opcode 0x200c failed: -71
[342869.002958] Bluetooth: hci0: Unable to disable scanning: -71
[342869.002973] Bluetooth: hci0: Unable to disable scanning: -71
[342869.003963] Bluetooth: hci0: Opcode 0x200c failed: -71
[342869.003989] Bluetooth: hci0: Unable to disable scanning: -71
[342869.004004] Bluetooth: hci0: stop background scanning failed: -71
[342879.009641] Bluetooth: hci0: Opcode 0x200c failed: -71
[342879.009667] Bluetooth: hci0: Unable to disable scanning: -71
[342879.009682] Bluetooth: hci0: Unable to disable scanning: -71
[342879.010637] Bluetooth: hci0: Opcode 0x200c failed: -71
[342879.010660] Bluetooth: hci0: Unable to disable scanning: -71
[342879.010675] Bluetooth: hci0: stop background scanning failed: -71
[342889.012366] Bluetooth: hci0: Opcode 0x200c failed: -71
[342889.012392] Bluetooth: hci0: Unable to disable scanning: -71
[342889.012407] Bluetooth: hci0: Unable to disable scanning: -71
[342889.013351] Bluetooth: hci0: Opcode 0x200c failed: -71
[342889.013372] Bluetooth: hci0: Unable to disable scanning: -71
[342889.013387] Bluetooth: hci0: stop background scanning failed: -71
[345023.606440] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[345023.608386] Bluetooth: hci0: RTL: rom_version status=0 version=1
[345023.608396] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[345023.608879] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[345023.608966] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[345024.210450] Bluetooth: hci0: RTL: fw version 0x75b8f098
[353735.638853] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[353735.640833] Bluetooth: hci0: RTL: rom_version status=0 version=1
[353735.640845] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[353735.641134] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[353735.641184] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[353736.242898] Bluetooth: hci0: RTL: fw version 0x75b8f098
[357728.607563] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[357728.609542] Bluetooth: hci0: RTL: rom_version status=0 version=1
[357728.609550] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[357728.609924] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[357728.609991] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[357729.211636] Bluetooth: hci0: RTL: fw version 0x75b8f098
[373216.616103] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[373216.618108] Bluetooth: hci0: RTL: rom_version status=0 version=1
[373216.618117] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[373216.618474] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[373216.618542] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[373217.220154] Bluetooth: hci0: RTL: fw version 0x75b8f098
[395964.610420] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[395964.612408] Bluetooth: hci0: RTL: rom_version status=0 version=1
[395964.612418] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[395964.612892] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[395964.612973] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[395965.214476] Bluetooth: hci0: RTL: fw version 0x75b8f098
[441581.637938] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[441581.639921] Bluetooth: hci0: RTL: rom_version status=0 version=1
[441581.639931] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[441581.640392] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[441581.640482] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[441582.242003] Bluetooth: hci0: RTL: fw version 0x75b8f098
[558951.608594] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[558951.610561] Bluetooth: hci0: RTL: rom_version status=0 version=1
[558951.610566] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[558951.610806] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[558951.610855] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[558952.212644] Bluetooth: hci0: RTL: fw version 0x75b8f098
[568268.609953] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[568268.611935] Bluetooth: hci0: RTL: rom_version status=0 version=1
[568268.611940] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[568268.612167] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[568268.612217] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[568269.215402] Bluetooth: hci0: RTL: fw version 0x75b8f098
[598155.609520] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[598155.611522] Bluetooth: hci0: RTL: rom_version status=0 version=1
[598155.611532] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[598155.611986] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[598155.612060] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[598156.213577] Bluetooth: hci0: RTL: fw version 0x75b8f098
Do you have any idea why my Bluetooth adapter isn’t working?
Greetings from Stefan Harbich
Seems the kernel drivers don’t like something when trying to talk with the adapter… it could be that the incorrect firmware/version is being loaded.
Are you using HAOS?
Which adapter are you using?
Is it one of the ones listed in the following:
i had forgotten to configure the USB adapter in Homeassistant. After configuring it in HomeAssistant everything works again. Greetings from Stefan Harbich.
I’m getting the same issues and codes - can you please help me out with how you configured it? There is a configure button but all I have as an option is passive scanning.
