I’m using a VM for Home Assistant.
I just received a USB adapter for HA : Digitus DN-30210-1.
I think I configure well the pathtrough : (I’ve also a Zigbee key and Google Coral). The third is bluetooth key.
But I’m not sure the key is working well.
I try the command :
service bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
Active: active (running) since Thu 2024-08-01 16:03:06 CEST; 2h 37min ago
Docs: man:bluetoothd(8)
Main PID: 136566 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9212)
Memory: 728.0K
CPU: 39ms
CGroup: /system.slice/bluetooth.service
└─136566 /usr/libexec/bluetooth/bluetoothd
août 01 16:03:06 Proxmox bluetoothd[136566]: Starting SDP server
août 01 16:03:06 Proxmox bluetoothd[136566]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
août 01 16:03:06 Proxmox bluetoothd[136566]: src/plugin.c:plugin_init() Failed to init vcp plugin
août 01 16:03:06 Proxmox bluetoothd[136566]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
août 01 16:03:06 Proxmox bluetoothd[136566]: src/plugin.c:plugin_init() Failed to init mcp plugin
août 01 16:03:06 Proxmox bluetoothd[136566]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
août 01 16:03:06 Proxmox bluetoothd[136566]: src/plugin.c:plugin_init() Failed to init bap plugin
août 01 16:03:06 Proxmox bluetoothd[136566]: Bluetooth management interface 1.22 initialized
août 01 16:03:06 Proxmox bluetoothd[136566]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
août 01 16:03:06 Proxmox bluetoothd[136566]: sap-server: Operation not permitted (1)
root@Proxmox:~# lusb
-bash: lusb : commande introuvable
root@Proxmox:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 003: ID 18d1:9302 Google Inc.
Bus 001 Device 002: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Cause on Home Assistant, I see the key, but I don’t succeed to contact my sensors.
