I’m having trouble to initialize the integrated bluetooth on Raspberry Pi 3B with HassOS 1.7, both 32bit and 64bit images. The add-on (v2.3) fails with following message:
bcm43xx_init
Failed to write reset command
Can't initialize device: No error information
I’ve tried with two different Raspberry Pi units - same result.
The BCM add-on is not made for Hass.io on HassOS. HassOS uses Bluez which is installed by default. Though there are some problems with it in the current version.
I also have the problem with Bluetooth. Here is the log of my mistake
> Error setting up platform bluetooth_tracker
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 183, in async_setup_platform
disc_info)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 72, in setup_scanner
for dev in discover_devices():
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 50, in discover_devices
lookup_class=False)
File "/usr/lib/python3.6/site-packages/bluetooth/bluez.py", line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 19] No such device
