Bluetooth BLE tracker on Raspian Stretch
Hi all,
I just updated Raspian and now the Bluetooth LE doesn’t work.
This is the error that I found in my log:
ERROR (Thread-20) [homeassistant.util.package] Unable to install package gattlib==0.20150805: Command "/srv/homeassistant/homeassistant_ven
I tried this solution but it doesn’t work.
I also tried installing libboost-all-dev as suggested here but without results!
Can someone please support me?
Thank you all in advance!
I’m still fighting with this issue.
I tried to manuall install gattlib but i receive this error:
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-ak_jeroh/gattlib/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-vuy6qv38-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-ak_jeroh/gattlib/
I’m the only one with this issue?
