I created an automation to open my garage door if I enter home zone with a condition that my phone is connected to my truck’s bluetooth. I cannot figure out why it is evaluating false.
I’m brand new to HA and this is my first post. Thank you all for your help.
alias: Open Garage Door
description: When entering home and connected to truck bluetooth
- platform: zone
entity_id: person.andrew
zone: zone.home
event: enter
condition:
- condition: state
entity_id: sensor.pixel_4a_bluetooth_connection
attribute: connected_paired_devices
state: 04:A3:16:7D:74:12 (TOYOTA Tacoma)
- device_id: a2027347c51c2db0832ff397f64c1b2d
domain: mobile_app
type: notify
title: "[TEST] Garage Door Open"
message: >-
If you are seeing this message, the the garage door should have opened
correctly. Were you entering home and connected to truck bluetooth?
mode: single
- platform: zone
zone: zone.home
event: enter
condition:
- condition: template
value_template: >
{% set x = state_attr('sensor.pixel_4a_bluetooth_connection', 'connected_paired_devices') %}
{% set x = x if x is string else x[0] %}
{{ '04:A3:16:7D:74:12' in x }}
domain: mobile_app
type: notify
message: >-
mode: single
@123
That did it! I don’t fully understand what you did, though. Could you explain it? And why does the visual editor not work in this case? Thank you!
If the Automation Editor played any part in causing the problem then I don’t know what it might have been.
The Template Condition first retrieves the value of the sensor’s connected_pairs_devices attribute and assigns it to the variable named x.
Just in case the retrieved value might be either a string or a list, it checks if it’s a string. If it is then the value of x is used as-is. However, if it’s not a string then it’s assumed to be a list so x is assigned the value of the first item in the list (list items are indexed starting with zero).
Finally, the template checks if the string 04:A3'16:7D:74:12 is within the value of x. If it is then the result is true otherwise false.
