Bluetooth config in docker container doesn't show?
I have followed the instructions here Bluetooth - Home Assistant
but it seems the integration cannot be loaded ? It just says ‘No Unconfigured Bluetooth adaptors found’
I checked and the adaptor is visable to the docker container but using the bluetoothctl command from within the container does not work? Output below. Any help would be appreciated, host system is Alma Linux 8.6. I am using the ZEXMTE BT-505 listed as recommended.
[root@Server ~]# bluetoothctl
Agent registered
[CHG] Controller 00:E0:4C:E7:B9:03 Pairable: yes
[bluetooth]# scan on
Discovery started
[CHG] Controller 00:E0:4C:E7:B9:03 Discovering: yes
[NEW] Device 74:40:BB:59:C5:3C KD-65XF9005
[bluetooth]# exit
[root@Server ~]#  docker exec -it home-assistant-BT /bin/bash
bash-5.1# hciconfig -a
hci0:   Type: Primary  Bus: USB
        BD Address: 00:E0:4C:E7:B9:03  ACL MTU: 1021:6  SCO MTU: 255:12
        UP RUNNING
        RX bytes:3541 acl:0 sco:0 events:286 errors:0
        TX bytes:31821 acl:0 sco:0 commands:278 errors:0
        Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
        Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
        Link policy: RSWITCH HOLD SNIFF PARK
        Link mode: PERIPHERAL ACCEPT
        Class: 0x000000
        Service Classes: Unspecified
        Device Class: Miscellaneous,
        HCI Version: 5.1 (0xa)  Revision: 0x9a9
        LMP Version: 5.1 (0xa)  Subversion: 0x8a6b
        Manufacturer: Realtek Semiconductor Corporation (93)
bash-5.1# bluetoothctl
No default controller available
[bluetooth]#
