I have a problem setting bluetooth dongle in my ha. I’m running debian bullseye with supervised installation. Both ha and debian are fully updated to the latest stable version.
When I reboot my comp I get this error
On system when I run hciconfig -a I get this
hci0: Type: Primary Bus: USB
BD Address: 00:1A:7D:DA:71:05 ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING
RX bytes:696 acl:0 sco:0 events:30 errors:0
TX bytes:417 acl:0 sco:0 commands:37 errors:0
Features: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: SLAVE ACCEPT
Can't read class of device on hci0: Connection timed out (110)
I installed dbus-broker and enabled it.
When I run sudo systemctl status dbus-broker I got this
It seems that after reboot bluetooth dongle doesnt work and it’s not recognized in home assistant.
But if I restart dbus-broker my bluetooth dongle is recognized but I get his
I can’t see in the menu configuration for network interfaces.
and I can’t open ssh web terminal because it’s waiting for supervisor to startup.
If I do hciconfig -a I get his
In my opinion something problem might be in the dbus socket and its avability to home assistant. I’m not sure is this a case, its my guess. But if it is I don’t know how to fix it.
Edit:
After checking some things I found out that mdns stoped running after I restarted dbus-broker. I removed avahi-daemon from my system but it didn’t changed anything.
lsusb
Bus 003 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 002: ID c0f4:05e0 SZH usb keyboard
Bus 002 Device 004: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
My adapter is recognized by home assistant but I get unsupported system errors. I checked the docs and it says "The Bluetooth adapter must be accessible to D-Bus ". It’s seems to me that it isn’t accessible to dbus on reboot but if I restart dbus it became available but it breaks some things in ha.
Can someone help me out with this?
Ok, I got this working by restarting Network Manager and hassio-supervisor services. But I still got unsuported installation problem.
The problem is obviously related to dbus. When I do in ssh terminal
I can’t believe it. In /etc/systemd/system/hassio-supervisor.service I just added a line like @k96hkh suggested in this thread and just done systemctl daemon-reload and volla.
No dbus errors, system is supported and everything is working.
After whole weekend trying to make my bluetooth adapter work, I think I found a permanent solution for it. I’m using debian 11 and I reverted all my editing to defaults. I upgraded my kernel to 6.0 from testing branch.
In /etc/apt/sources.list I added
deb http://deb.debian.org/debian/ testing main contrib non-free
deb-src http://deb.debian.org/debian/ testing main contrib non-free
and upgraded my kernel. Bluetooth adapter is recognized on boot and I don’t see any errors or problems for know.
I hope this is the end of the road for me and my adapter.
