Bluetooth connection
Hi
I’m trying to write a pyhton app to interrogate the InkBird IBS-TH2 bt I can’t discover the MAC address or the UUIC I need.The Engbird app says the address is 49:24:06:18:03:57 but I can’t connect to it? Any suggestions very welcome
Are you in range? Can you find the device in python if you run a BT scan (I assume since you’re writing for HA with bleak). Does the device even allow active connections or only BT advertisements?
