For the life of me I can’t get the bluetooth device tracker working. The log produces the following error:
2017-08-27 15:30:55 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/init.py”, line 160, in async_setup_platform
disc_info)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 64, in setup_scanner
for dev in discover_devices():
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 42, in discover_devices
lookup_class=False)
File “/srv/homeassistant/lib/python3.4/site-packages/bluetooth/bluez.py”, line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 19] No such device
I’ve had it working before with previous builds. The only topic I’ve found was closed with the proposed solution to upgrade to the current HASS release.
2017-08-27 09:58:26 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 160, in async_setup_platform
disc_info)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 64, in setup_scanner
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 42, in discover_devices
lookup_class=False)
File "/usr/lib/python3.6/site-packages/bluetooth/bluez.py", line 26, in discover_devices
