I am running Hass.io in a VM on Proxmox on a NUC, but are having problems getting device tracking by Bluetooth working.
This error shows up in my log:
2019-02-24 15:14:54 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/init.py”, line 184, in async_setup_platform
disc_info)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 81, in setup_scanner
for dev in discover_devices():
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 59, in discover_devices
lookup_class=False, device_id=device_id)
File “/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py”, line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 97] Address family not supported by protocol
Same issue here. I connected the internal bluetooth of the NUC as an USB port to the VM (running Hassos), but it looks like this is currently not supported yet.
Documentation states that we should enable AutoEnable in /etc/bluetooth/main.conf by changing false to true and of course remove the # in front of it. But I cannot get that to work.
More info at archlinux wiki
Thanks for update, I’m unsure if it should be reported somewhere as a problem, especially with more and more switching to NUCs… I really miss the BT/BLE on my setup now with the bt not working on my nuc in proxmox…
I am in the same boat with not being able to get Bluetooth working in a hass.io Proxmox VM.
I think you are right that more people are switching to NUC machines and Proxmox so it would be good if HA could support these in the future.
I just cannot find presence detection that is as reliable as BT so really missing this now. What have you been using for presence detection now you cannot use BT?
I ended up setting up the Bluetooth presence monitor that was mentioned on these forums and it’s been rock solid. I have it running under another VM that i already had on my proxmox setup.
My internal Intel Bluetooth shows up as a USB device so I passed that on to an existing VM running. After that I installed monitor with these instructions:
and played around with it until I was comfortable. After I got the gist of it I installed it on a pi zero w and set both to scan for arrival and departure only on specific triggers and publish mqtt messages for each device home or not_home
