I’m running HA 0.35.2 and trying to get the bluetooth LE tracker going. I followed the configuration docs for the bluetooth LE tracker and I can run: sudo hcitool lescan successfully.
In my HA log, I see devices being recognized, for example… INFO:homeassistant.components.device_tracker.bluetooth_le_tracker:Discovered Bluetooth LE device 28:FD:80:81:0A:59 is reported.
However, there’s no entry in my known_devices.yaml that corresponds with this MAC address. I also get the following errors in the log:
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 285, in async_see
yield from device.set_vendor_for_mac()
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 479, in set_vendor_for_mac
self.vendor = yield from self.get_vendor_for_mac()
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 496, in get_vendor_for_mac
oui = '{:02x}:{:02x}:{:02x}'.format(*[int(b, 16) for b in oui_bytes])
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 496, in <listcomp>
ValueError: invalid literal for int() with base 16: 'BLE_14'
16-12-21 21:02:25 homeassistant.core: Error doing job: Task exception was never retrieved
result = next(coro)
ValueError: invalid literal for int() with base 16: 'BLE_C8'
result = next(coro)
ValueError: invalid literal for int() with base 16: 'BLE_D5'
Any suggestions?
