I’m a little confused with how to set up BT properly for tracking - looking for some guidance.
I have been using Bluetooth for connectivity to a Yale lock, using a USB BT adapter configured using the Bluetooth integration. However, because my HA server is in a metal rack, I had to run a long cable to get the adapter close enough to the lock to work.
To get rid of the long cable and adapter I bought 2 x ESP32 devices, added as Bluetooth proxies, one next to the door with the lock. I removed the USB BT adapter and HA is using the ESP32 device fine for BT - it locks and unlocks the door; BT proxy is working.
As there is no longer a connected BT adapter I removed the Bluetooth integration (it will only work with a bluetooth adapter).
With ESP32 proxies in the house I’d like to use Bluetooth Tracker and Bluetooth LE Tracker.
Following Bluetooth Tracker - Home Assistant and Bluetooth LE Tracker - Home Assistant I put the following in configuration.yaml:
device_tracker:
- platform: bluetooth_tracker
new_device_defaults:
track_new_devices: true
- platform: bluetooth_le_tracker
Both fail.
BT LE tracker:
2023-01-06 21:52:35.454 WARNING (MainThread) [homeassistant.components.bluetooth_le_tracker.device_tracker] No Bluetooth LE devices to track!
2023-01-06 21:52:35.455 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy bluetooth_le_tracker
BT Tracker:
2023-01-06 21:52:47.455 ERROR (SyncWorker_1) [homeassistant.components.bluetooth_tracker.device_tracker] Couldn't discover bluetooth devices: [Errno 19] No such device
2023-01-06 21:52:47.456 ERROR (MainThread) [homeassistant.components.bluetooth_tracker.device_tracker] Error looking up Bluetooth device
My ESP32s are setup with:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
I’ve obviously misunderstood something fundamental… It looks like I can’t setup trackers without an adapter, but I thought the whole idea of using ESP32s with BT proxy was so a local adapter was not needed?
How should I setup to get BT and BT LE Tracking to work using the ESP32s?
