Has Bluetooth stopped working? Suddenly none of my BT devices gets updated, and I can find the following in the log:
Logger: homeassistant.components.bluetooth_tracker.device_tracker
Source: components/bluetooth_tracker/device_tracker.py:57
Integration: bluetooth_tracker (documentation, issues)
First occurred: 11:13:59 AM (78 occurrences)
Last logged: 11:44:47 AM
Error looking up Bluetooth device
File "/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py", line 30, in discover_devices
results = _bt.hci_inquiry (sock, duration=duration, flush_cache=True,
_bluetooth.error: (110, 'Operation timed out')
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 140, in perform_bluetooth_update
devices = await hass.async_add_executor_job(discover_devices, device_id)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 57, in discover_devices
result = bluetooth.discover_devices(
File "/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py", line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
