Bluetooth not working on Pi Zero 2 W
It is the first time I run hassOS. Before I was running Core on a dedicated Docker host.
I have trouble getting Bluetooth to work on a Pi Zero 2 W. For me it seems everything loaded properly:
# systemctl status bluetooth-bcm43xx.service
● bluetooth-bcm43xx.service - Bluetooth for BCM43xx
     Loaded: loaded (/usr/lib/systemd/system/bluetooth-bcm43xx.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-02-21 19:46:58 UTC; 3min 42s ago
    Process: 335 ExecStart=/usr/bin/btuart (code=exited, status=0/SUCCESS)
   Main PID: 379 (hciattach)
      Tasks: 1 (limit: 866)
     Memory: 240.0K
     CGroup: /system.slice/bluetooth-bcm43xx.service
             └─379 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:a3:ec:f5
Feb 21 19:46:57 homeassistant systemd[1]: Starting Bluetooth for BCM43xx...
Feb 21 19:46:57 homeassistant btuart[369]: Patch not found, continue anyway
Feb 21 19:46:58 homeassistant btuart[369]: bcm43xx_init
Feb 21 19:46:58 homeassistant btuart[369]: Set BDADDR UART: b8:27:eb:a3:ec:f5
Feb 21 19:46:58 homeassistant btuart[369]: Set Controller UART speed to 3000000 bit/s
Feb 21 19:46:58 homeassistant btuart[369]: Device setup complete
Feb 21 19:46:58 homeassistant systemd[1]: Started Bluetooth for BCM43xx.
But obviously it doesn’t work
# bluetoothctl
Agent registered
[bluetooth]# scan on
No default controller available
I tried restarting the bluetooth-bcm43xx.service but it won’t start up again. I verified my Pi Zero 2 W is able to scan for devices running latest raspiOS (lite). There I needed to restart some hciuart.service
Do you have any ideas?
Any ideas appreciated.
# ha info
arch: armv7
channel: stable
docker: 20.10.9
features:
- reboot
- shutdown
- services
- network
- hostname
- timedate
- os_agent
- haos
hassos: "7.4"
homeassistant: 2022.2.9
hostname: homeassistant
logging: info
machine: raspberrypi3
operating_system: Home Assistant OS 7.4
state: running
supervisor: 2022.01.1
supported: true
supported_arch:
- armv7
- armhf
timezone: Europe/Berlin
Hi
Have you tried bluetoothctl power off and the bluetoothctl power on ?
You have HAOS on a pi zero?
I think that is not a recommended idea.
the problem is still the same: no controller
# bluetoothctl power off
pi zero 2 w. it should be the same performance as a pi3 (as I read in the forum). I know it is not high end hardware, but it fits my use case. I have a low power device, i.e. pi zero 2 W with lan/usb HAT. so no wireless. From what I read it should work.
So my question persists: what am I missing about bluetooth as with raspiOS it is working
what I also found, after reading of plenty of bluetooth threads:
# hciconfig -a
hci0:	Type: Primary  Bus: UART
	BD Address: B8:27:EB:A3:EC:F5  ACL MTU: 1021:8  SCO MTU: 64:1
	DOWN
	RX bytes:1250 acl:0 sco:0 events:66 errors:0
	TX bytes:810 acl:0 sco:0 commands:66 errors:0
	Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy: RSWITCH SNIFF
	Link mode: PERIPHERAL ACCEPT
# hciconfig hci0 up
Can't init device hci0: Invalid request code (56)
Don’t know if this helps to troubleshoot the problem
The only clue I have found is that the Pi02W may require an updated firmware… I got that suggestion from here https://forums.slimdevices.com/showthread.php?115331-New-RPi-Zero-2-W&p=1038069 (of course PCP uses completely different packages, so don’t try looking for their .tcz packages)
thanks for pointing this out. so the chipset for the integrated wifi/bluetooth module is different to the pi3 and this might need new firmware? as nobody complained about wifi yet so this might luckily work/is compatible.
Would we require a special Pi02W image or just another firmware put into the the Pi3 image. As I see on the specs the Pi3 has also different BCMs for Wifi/Bluetooth so I expect they just reside next to each other in the image?
I this the right place here or should I open an issue on GitHub?
