Bluetooth not working with any device
I am using the latest image from home-assistent.io on a rasperry pi 4 (Raspberry Pi - Home Assistant). With bluetoothctl in Terminal, it will discover some devices.
S 679
But when using the Integration, it always says “No unconfigured bluetooth adapters found”.
I am trying to connect to a switchbot curtain, which is already registered within the app.
What am I missing?
Thank you
greetings
Christian
I’ve the same issue adding the integration “No configured bluetooth adapters found”.
Scanning the devices, I can see the one I would like to install (a switch bot).
The device (and some others) were working fine when I used the “Passive BLE monitor integration”
Is there a way to “reset” the bluetooth adabter? I’m using HA core on a Raspberry 4.
Thanks for any help.
Stefano
have you found any solution?
