Did unfortunately not work for me. I’m still getting this error message:
Error setting up platform bluetooth_tracker
File “/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py”, line 31, in discover_devices
lookup_class=lookup_class, device_id=device_id)
_bluetooth.error: (110, ‘Operation timed out’)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 184, in async_setup_platform
disc_info)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 73, in setup_scanner
for dev in discover_devices():
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 51, in discover_devices
lookup_class=False)
File “/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py”, line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
Edit Edit: Bluetooth seems to have crashed again overnight. Seems to be some stability issues there by the looks of things.
Edit: Looks like issuing a ‘hassio host reboot’ triggered it to work again. Not sure why it dies all of a sudden.
I am having same issue on 0.82.1 (HassOS 32bit RaspberryPi 3) - Bluetooth is broken again
File "/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py", line 31, in discover_devices
_bluetooth.error: (110, 'Operation timed out')
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 184, in async_setup_platform
disc_info)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 73, in setup_scanner
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 51, in discover_devices
lookup_class=False)
File "/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py", line 34, in discover_devices
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter```
I keep getting the same problem, but on mine, a restart only fixes the problem for about a minute. All the devices are then away forever
RaspberryPi 3
HA version: 0.82
HassOS 1.13 (32 bit)
Annoying I only recently switch from hassio 64bit to 32bit as it was causing problems with GPIO. On the 64bit hassio worked fine for months.
2018-11-29 10:18:20 ERROR (SyncWorker_8) [homeassistant.components.device_tracker.bluetooth_tracker] Error looking up Bluetooth device
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 93, in update_bluetooth_once
lookup_class=False)
It was working flawlessly for over a year, today without any updates or changes it decided to give up…
2019-03-13 13:18:30 ERROR (SyncWorker_1) [homeassistant.components.device_tracker.bluetooth_tracker] Error looking up Bluetooth device
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 31, in discover_devices
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 101, in update_bluetooth_once
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 59, in discover_devices
lookup_class=False, device_id=device_id)
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 34, in discover_devices
to my config file, and my phone did show up in my known devices, with my BT mac, so THAT … worked, but when i then looked at the page where i have the gps tracking and battery status of all the phones in this household, they all had changed from working well to just saying : Away, on location, and on battery status they said : Unknown.
Anyone seen this happen before? I use gps tracking and battery state via google maps.
I know if you have the iOS app installed AND the BT tracker enabled, that it will switch between gps and BT when you look at the dev-states page. example below…
device_tracker.my_iphone home source_type: bluetooth
device_tracker.her_iphone not_home source_type: gps
I would get these same errors and the communication timeout shows up when running this command. To fix (use the hci interface for bluetooth reported by the prior command):
sudo hciconfig hci0 up
Check your /etc/bluetooth/main.conf in the [Policy] section: you should have AutoEnable=true. This was already present on my system.
I still get periodic errors in my log but the bluetooth trackers seem to work and my RPi now survives reboots with working bluetooth. Good luck!
