I added a know_devices.yaml and put my phone in it
and now it shows up but stays on away.
Log Details (ERROR)
Tue Sep 04 2018 20:15:58 GMT-0700 (PDT)
Error setting up platform bluetooth_tracker
File "/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py", line 31, in discover_devices
lookup_class=lookup_class, device_id=device_id)
_bluetooth.error: (110, 'Operation timed out')
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 183, in async_setup_platform
disc_info)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 72, in setup_scanner
for dev in discover_devices():
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 50, in discover_devices
lookup_class=False)
File "/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py", line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
I had read that in other posts and never installed the BCM Add-on
After I could not get it working, then I installed it to see if that would fix
the issue and still got the same problem, then un-installed it.
Also had read something about the the known_devices.yaml not being used anymore.
I was getting the error can not create know_devices until I created one and copied it into
my config directory.
Was that wrong should it be in the .storage now or should I not have one at all?
After that I get the sensor badge for my phone but the bluetooth tracking is not loaded.
I had an existing known_devices.yaml file from my own_tracks install but it was automatically created at that time. I think you may want to delete that file you created just because maybe the permissions are wrong on it.
Turned on my bluetooth on ZTE cell phone, waited a few seconds and saw in my known_devices.yaml:
Just tried a clean install of latest build to see if I could get it to work
fresh out of the box.
Now I get a login page and enter info.
After that it goes to a loading data screen and never goes past
Let it run for over a hour and tried 3-4 clean installs.
Also the image I downloaded a week ago was hassos_rpi3-2.2.img
the one that is there today is hassos_rpi3-32-1.10.img
anyone know why the current one is a lower version?
I run a Raspberry PI3 and was just doing the restart in the configuration panel
After doing a complete power down and reboot everything has been fine since.
Thanks for the quick response. That’s what I thought but I was hoping you meant something else because doing a hard reboot has not fixed the Bluetooth issue for me unfortunately.
Scroll back and check the dialog about BCM. If that is not the issue, and this is a new install, at this point I can only suggest starting over with the installation.
I wish I could offer more but I have found with PI and bluetooth, it either works right out of the box or… it doesn’t work at all.
Thanks @Dixey and @wakeskate for the suggestions. I updated to the latest version and the Bluetooth presence detection seems to work now…kinda lol. The sensor itself is correct in saying that I (Jake) am home, however, the state history graph is all wrong. I have noticed this on other, non-bluetooth sensors as well. Any ideas?
Did you change anything else? I have downloaded the latest Hass.io RPi3 image yesterday but seeing the exact same error message you’ve got in the beginning…
Try deleting your database. I have since switched to MariaDB but I fixed the problem when I was still using SQlite by stopping the server, deleting the DB and starting back up. A new DB will be created. I hope this works for you.
