Hello.
I have a system with a deployed on Raspberry 3b that works fine.
I am trying to install HA on a mini PC j4125 processor with win10.
I created a hyper-x virtual machine and installed the appropriate system image.
HA started, but I ran into some problem.
HA on the miniPC does not see bluetooth sensors, which are perfectly visible from raspberries 3b. As I understand it, ha does not see the sensors due to the fact that the bluetooth is not connected to the virtual machine. Bluetooth module is built into the motherboard.On the forums, it is found that you can give a virtual machine access to local PC resources if the virtual machine is running in advanced mode, but this option is not available for the image downloaded from the Home Assistant website. I haven’t found a solution. How can i connect bluetooth to a virtual machine?
