I successfully installed HomeAssistant on my ageing Windows Home Server (WHS 2011 which is basically a WIndows Server 2008 R2 x64). Most things went quite smooth, but I am running into issues when trying to use the bluetooth tracker. This is the error that is being thrown when starting up HA:
←[32m2018-01-17 20:35:16 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.bluetooth
_tracker←[0m
←[31m2018-01-17 20:35:16 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetoot
h_tracker←[0m
File "c:\program files (x86)\python36-32\lib\site-packages\homeassistant\components\device_tracker\__init__.py", line
169, in async_setup_platform
disc_info)
File "c:\program files (x86)\python36-32\lib\asyncio\futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "c:\program files (x86)\python36-32\lib\asyncio\tasks.py", line 250, in _wakeup
future.result()
File "c:\program files (x86)\python36-32\lib\asyncio\futures.py", line 243, in result
raise self._exception
File "c:\program files (x86)\python36-32\lib\concurrent\futures\thread.py", line 56, in run
File "c:\program files (x86)\python36-32\lib\site-packages\homeassistant\components\device_tracker\bluetooth_tracker.p
y", line 32, in setup_scanner
import bluetooth
File "C:\Users\Administrator\AppData\Roaming\.homeassistant\deps\Python36\site-packages\bluetooth\__init__.py", line 3
9, in <module>
from bluetooth.msbt import *
File "C:\Users\Administrator\AppData\Roaming\.homeassistant\deps\Python36\site-packages\bluetooth\msbt.py", line 2, in
<module>
import bluetooth._msbt as bt
ImportError: DLL load failed: The specified module could not be found.←[0m
Can anyone spot the error or point me in the right direction?
Wolfgang
