dietzi
(Dietzi)
December 30, 2023, 4:28pm
1
Hello. I use an Intel NUC with Bluetooth onboard. However, I have problems with the Delonghi integration. It seems as if the data is split over Bluetooth and therefore not processed correctly by the integration. Can/must I set something somewhere so that the data arrives properly?
This integration is used via HACS: GitHub - Arbuzov/home_assistant_delonghi_primadonna: Home assistant integration for the Delonghi coffee machine
dietzi
(Dietzi)
December 31, 2023, 10:12am
3
Edwin_D
(Edwin D.)
December 31, 2023, 10:28am
4
Maybe bluetooth reception isn’t that good and it is dropping information because of it? My suggestion would be to spend €10 to €15 to create an ESP bluetooth proxy that you can place nearby:
dietzi
(Dietzi)
December 31, 2023, 10:35am
5
The coffee machine is 2m away from the NUC
Edwin_D
(Edwin D.)
December 31, 2023, 10:56am
6
And how much interference is around it, such as USB3 and other devices? Does it have a separate antenna for bluetooth or is it sharing with wifi?
Edwin_D
(Edwin D.)
December 31, 2023, 11:23am
7
Seems there are problems with newer linux kernels on NUC, maybe related?
opened 10:55PM - 02 May 23 UTC
waiting-for-upstream
integration: bluetooth
# Mod Issue Summary - Read First
See https://lore.kernel.org/linux-bluetooth/… [email protected] /T/#mb094e06d495879436ce9a8722ad7ad87527ea74b
A summary:
- Bluetooth initialization is unreliable/broken on newer linux kernels for a large sample of adapters
- No fixes are available without patching the kernel and it will likely be a LONG time before debian updates the kernel, if you want to manually compile and patch your kernel, see https://lore.kernel.org/linux-bluetooth/CABBYNZ+5RMqNVMyYKi+gOVaV+K6k8Z-C37KnfGa=qRUORc3dWg@mail.gmail.com/ https://github.com/home-assistant/operating-system/pull/2714
- Newer Home Assistant OS has some patches that solves the problem for some adapters so be sure you have the latest HAOS: https://github.com/home-assistant/operating-system/issues/2485 https://github.com/home-assistant/operating-system/issues/2535
- The recommended workaround if you can't run HAOS or patch the kernel manually is to use an ESPHome proxy instead https://esphome.github.io/bluetooth-proxies/
### The problem
Bluetooth integration in perpetual state of initializing / retrying setup.
Deleting integration, restarting HA and configuring after auto discovered, several times, does not resolve.
### What version of Home Assistant Core has the issue?
core-2023.4.6
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
bluetooth
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/bluetooth
### Diagnostics information
[home-assistant_bluetooth_2023-05-02T22-28-03.303Z.log](https://github.com/home-assistant/core/files/11378180/home-assistant_bluetooth_2023-05-02T22-28-03.303Z.log)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
Retrying setup: hci0 (XXXXX): Failed to start Bluetooth: [org.bluez.Error.InProgress] Operation already in progress
Logger: bluetooth_auto_recovery.recover
Source: components/bluetooth/util.py:78
First occurred: 5:36:41 PM (28 occurrences)
Last logged: 5:52:42 PM
Bluetooth adapter hci0 [XXXXXXXX] could not be reset due to timeout
Logger: homeassistant.config_entries
Source: config_entries.py:1242
First occurred: 5:44:58 PM (4 occurrences)
Last logged: 5:51:51 PM
Config entry 'XXXXX' for bluetooth integration not ready yet: hci0 (XXXXX): Failed to start Bluetooth: [org.bluez.Error.InProgress] Operation already in progress; Retrying in background
### Additional information
Home Assistant Yellow
## System Information
version | core-2023.4.6
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.10
os_name | Linux
os_version | 6.1.21-v8
arch | aarch64
timezone | America/Chicago
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4929
Installed Version | 1.32.1
Stage | running
Available Repositories | 1278
Downloaded Repositories | 10
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | May 3, 2023 at 7:00 PM
relayer_connected | true
relayer_region | us-east-1
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | false
remote_server | us-east-1-7.ui.nabu.casa
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 10.1
update_channel | stable
supervisor_version | supervisor-2023.04.1
agent_version | 1.5.1
docker_version | 23.0.3
disk_total | 234.0 GB
disk_used | 9.6 GB
healthy | true
supported | true
board | yellow
supervisor_api | ok
version_api | ok
installed_addons | Mosquitto broker (6.2.1), Studio Code Server (5.5.7), Terminal & SSH (9.7.0), Network UPS Tools (0.11.2)
</details>
<details><summary>Dashboards</summary>
dashboards | 3
resources | 6
views | 6
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | April 24, 2023 at 3:54 AM
current_recorder_run | May 2, 2023 at 5:36 PM
estimated_db_size | 652.32 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
dietzi
(Dietzi)
December 31, 2023, 11:41am
8
I dont know if it is a shared antenna. Other USB devices not present. All other Bluetooth Integrations work fine. Only the delonghi integration makes the problem.
dietzi
(Dietzi)
9
I dont think its related. All other thigns work fine with bluetooth
dietzi
(Dietzi)
December 31, 2023, 5:03pm
10
I’ve tested with a raspberry and it’s the same behavior. The data is split. So I think I have to change somwthing on HA. But what to change?
Edwin_D
(Edwin D.)
January 1, 2024, 10:45am
11
Then it could either be the delonghi itself close to interference or shielding (I don’t think a phone is a good reference because I think it usually has a way better antenna, and the rpi’s is not very good), or the delonghi integration builder needs to implement an entirely different api. This does not look like what you’d expect from the delonghi, not even split.
Another thing: are you absolutely sure you are talking to the right device? Using a ble scanner can be tricky, maybe you looked for the closest thing and found your smartwatch on the hand holding the scanner instead?
dietzi
(Dietzi)
January 1, 2024, 10:51am
12
I’m sure talking the right device. I can turn on the machine and cook coffee from HA. Maybe I have to sniff the data from my mobile phone to see wheter the data is split or not.
Edwin_D
(Edwin D.)
January 1, 2024, 10:52am
13
It could be a different api where each command has a different data length.
