I’ve been using the Bluetooth presence tracker for quite some time, but lately, I’ve been having more problems than ever before. I’m running Home Assistant in a pyenv on a Raspberry Pi 3B. I see a few other posts about this, but nothing has a solution. My Bluetooth tracker works for a while (lately, down to a few hours) and then stops detecting devices. If I restart Home Assistant, restart the RPi, or log in and run bluetoothctl and do a “scan on” and “scan off” it will start detecting devices again. The problem repeats in a few hours.
I’ve looked through the logs and don’t really see anything that corresponds to when the problems start. I do get Bluetooth errors, but they are at different times than when I’m losing devices. The only Bluetooth-related log entries I see are:
Jul 3 06:33:53 home kernel: [604650.442264] Bluetooth: hci0: Frame reassembly failed (-84)
Jul 3 06:33:55 home kernel: [604652.505296] Bluetooth: hci0: command 0x0401 tx timeout
Jul 3 06:34:09 home hass[13945]: 2019-07-03 06:34:09 ERROR (SyncWorker_8) [homeassistant.components.bluetooth_tracker.device_tracker] Error looking up Bluetooth device
Jul 3 06:34:09 home hass[13945]: Traceback (most recent call last):
Jul 3 06:34:09 home hass[13945]: File "/srv/homeassistant/lib/python3.7/site-packages/bluetooth/bluez.py", line 31, in discover_devices
Jul 3 06:34:09 home hass[13945]: lookup_class=lookup_class, device_id=device_id)
Jul 3 06:34:09 home hass[13945]: _bluetooth.error: (110, 'Connection timed out')
Jul 3 06:34:09 home hass[13945]: During handling of the above exception, another exception occurred:
Jul 3 06:34:09 home hass[13945]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/bluetooth_tracker/device_tracker.py", line 102, in update_bluetooth_once
Jul 3 06:34:09 home hass[13945]: for dev in discover_devices():
Jul 3 06:34:09 home hass[13945]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/bluetooth_tracker/device_tracker.py", line 57, in discover_devices
Jul 3 06:34:09 home hass[13945]: lookup_class=False, device_id=device_id)
Jul 3 06:34:09 home hass[13945]: File "/srv/homeassistant/lib/python3.7/site-packages/bluetooth/bluez.py", line 34, in discover_devices
Jul 3 06:34:09 home hass[13945]: raise BluetoothError ("error communicating with local "
Jul 3 06:34:09 home hass[13945]: bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
It lost the devices again around 2:30 AM 4 July, but there weren’t any log entries at that time. The closest one was a frame reassembly failed at 2:16 AM and there were other entries that didn’t affect the BT tracker.
I can’t figure out if I’m having a hardware failure or if this is a problem with the BT tracker. I’m not convinced it is hardware since I can get it working again by running “bluetoothctl”
I used to have very reliable and very good Bluetooth detection, but now it’s very annoying as it is frequently marking me as “away” when I’m still home, especially at night while I’m asleep.
Any suggestions?
