I have two ESP32s set up with bluetooth proxy. They are connected via wifi to my LAN. I updated via cable to make sure I have the new framework. I use them to be in close proximity to my two Level Bolt door locks.
They work fine, but sometimes the activation of the lock takes 20-30s from when I click the button in the UI. Is this expected? I thought the new framework was supposed to cache the connections so they would be faster. My experience is that sometimes they are faster and sometimes they take 20-30s. It seems that the long times are when the lock hasn’t been used in a while (like I was out and coming home). Is there some timeout for keeping the connection cached?
Anyway, I’m just not sure what the expected time is here. Thanks.
