Bluetooth proxy on ESP32 not finding any devices
Hey,
I just setup an ESP32 (WROOM-32U) using the web serial installer (ESPHome Bluetooth Proxy), connected it to my wifi & HA successfully, but it seems it cannot find any BT devices, I have a simple BLE beacon for testing and a SwitchBot bot (that is btw working fine with a second ESP of the same type using this integration: GitHub - devWaves/SwitchBot-MQTT-BLE-ESP32: Allows for multiple SwitchBot bots and curtains to be controlled via MQTT sent to ESP32. ESP32 will send BLE commands to switchbots and return MQTT responses to the broker. Also supports Temperature, Motion, Contact sensors
Both devices cannot be found by esphome, idk if I did something wrong, there’s not much that could go wrong with the web installer right? The BLE tag can be found by my phone btw, so I know it’s working.
Here’s the output of the serial console:
EDIT: using the debug logger I found out that it actually finds devices, but it seems it cannot do anything with them, any idea how to integrate for example this simple BLE tracking device for presence detection?
2022-10-03 12:00:15.448 DEBUG (MainThread) [homeassistant.components.bluetooth.manager] esp32-bluetooth-proxy-9c2548: 7C:2F:80:8F:16:E5 AdvertisementData(local_name='Gigaset G-tag', manufacturer_data={384: b'\x02\x15\x124\x80\x8f\x16\xe5\xbb\xc5'}, service_uuids=['0000180f-0000-1000-8000-00805f9b34fb']) connectable: False match: set() rssi: -57
Same issue for me with my GL-S10
(Has the same esp32)
It is seeing Bluetooth Devices in verbose log, but HA does not discover any devices
