Hi all!
I’m trying to setup a new instance of home assistant on my Raspberry Pi 4. I would like to integrate a Xiaomi H&T BLE ( LYWSD03MMC ) using the built-in bluetooth adapter.
I installed Home Assistant using Docker, this is the docker-compose.yml
version: '3'
services:
home-assistant:
container_name: home-assistant
image: homeassistant/home-assistant:2022.11.1
volumes:
- ./${PROJECT_DATAS_FOLDER}/home-assistant/config:/config
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
restart: unless-stopped
privileged: true
networks:
network1:
ipv4_address: ${NETWORK1_SUBNET}.78
dns:
- ${NETWORK1_SUBNET}.${NETWORK1_DNSIP}
devices:
- /dev/serial1:/dev/serial1
labels:
- "traefik.enable=true"
# .. other traefik labels
As shown by the docker-compose I am using Home Assistant version 2022.11.1 and I’d prefer not using the network mode host
As shown by the following screenshot, I am able to see the adapter in the integration page. However I cannot see the Xiaomi BLE device I want to integrate.
The Xiaomi BLE device is up and running, I can see it even from Windows and from my phone.
Additional information:
My host system has installed bluez-5.65-3
Linux kernel:
$ uname -a
Linux raspberry 5.15.74-2-MANJARO-ARM-RPI #1 SMP PREEMPT Thu Oct 20 16:43:17 UTC 2022 aarch64 GNU/Linux
I also tried to scan bluetooth devices using bluetoothctl from the host and from the docker, here the results:
# scan from the host
[pi@raspberry services]$ bluetoothctl scan on
Discovery started
[CHG] Controller E4:5F:01:**:**:** Discovering: yes
[NEW] Device A4:C1:38:**:**:** LYWSD03MMC
# open a shell inside the docker
[pi@raspberry services]$ docker exec -it home-assistant /bin/bash
# scan from the docker
bash-5.1# bluetoothctl scan on
Discovery started
[CHG] Device A4:C1:38:**:**:** RSSI: -54
In “settings → system → logs” I found this ERROR message:
Logger: homeassistant
Source: components/bluetooth/util.py:112
First occurred: 12:51:57 (164 occurrences)
Last logged: 14:15:04
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 372, in _async_scanner_watchdog
await self._async_reset_adapter()
File "/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py", line 389, in _async_reset_adapter
result = await async_reset_adapter(self.adapter)
File "/usr/src/homeassistant/homeassistant/components/bluetooth/util.py", line 112, in async_reset_adapter
return await recover_adapter(adapter_id)
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 251, in recover_adapter
async with MGMTBluetoothCtl(hci, MGMT_PROTOCOL_TIMEOUT) as adapter:
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 116, in __aenter__
await self._setup()
File "/usr/local/lib/python3.10/site-packages/bluetooth_auto_recovery/recover.py", line 137, in _setup
self.sock = btmgmt_socket.open()
File "/usr/local/lib/python3.10/site-packages/btsocket/btmgmt_socket.py", line 58, in open
raise BluetoothSocketError("Unable to open PF_BLUETOOTH socket")
btsocket.btmgmt_socket.BluetoothSocketError: Unable to open PF_BLUETOOTH socket
What am I doing wrong?
