Bluetooth speaker profile
I have a Marshall Willen 2 Bluetooth speaker (wich works also as a handsfree device, for example as a mic/speaker for phone or a softphone)
Following some guides i was able to pair and connect it with bluetooth in HA, once connected to it, getting the info from bluetoothct return
[WILLEN]> info
Device 78:5E:A2:D5:97:CD (public)
        Alias: WILLEN
        Class: 0x00240414 (2360340)
        Icon: audio-card
        Paired: yes
        Bonded: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Serial Port               (00001101-0000-1000-8000-00805f9b34fb)
        UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
        UUID: Advanced Audio Distribu.. (0000110d-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control Cont.. (0000110f-0000-1000-8000-00805f9b34fb)
        UUID: Handsfree                 (0000111e-0000-1000-8000-00805f9b34fb)
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: Vendor specific           (df21fe2c-2515-4fdb-8886-f12c4d67927c)
        Battery Percentage: 0x1e (30)
then when i get back to terminal and restart ha audio (ha audio restart)
HA disconnect and then reconnect but it looks it reconnect to Handsfree and i am not able to select it as output of my VLC Local Add on
[core-ssh ~]$ ha audio info
audio:
  application: []
  card:
  - driver: module-bluez5-device.c
    index: 0
    profiles:
    - active: false
      description: Handsfree Head Unit (HFP)
    - active: true
      description: "Off"
  input: []
  output:
  - applications: []
    card: null
    default: true
    description: Dummy Output
    index: 0
    mute: false
    volume: 1
host: 172.30.32.4
update_available: false
version: 2025.08.0
version_latest: 2025.08.0
i tried to connect passing the profile UUID (the command works correctly) but it looks output of ha audio is alwasy “Dummy Output”.
in the past (for no obvious reason) i was able to connect to audio sink, and have the bluetooth speaker as an output for my Local VLC
any suggestion?
