Hi everybody !
I’ve got a question,
how could I use a bluetooth speaker with my HA on my raspberry pi 3 ?
Because I wanna use a TTS component but I haven’t solution to create a link between HA & bluetooth…
Do you have a solution ?
Thank you !!!
Hi everybody !
Thank you !!!
Hello! I have the same quesiton and almost same requirement except I want to play media on my bluetooth speaker from home assistant. I managed to have the speaker paired and connected with the Pi 3b+ using BluetoothCTL command line but after that… no idea what to do. In Home Assistant, I can see the bluetooth radio from the rapberry pi but no other device, no speaker… In media player my only option is to play on “browser” I can’t output to the bluetooth speaker as it does no showup. Any advice?
