Bluetooth stopped working
Hi all,
BT has been working OK in my docker installation of HA, but today it has stopped working. Logs show it’s timing out.
2022-12-11 16:59:08.091 WARNING (MainThread) [homeassistant.config_entries] Config entry '04:7F:0E:25:C5:58' for bluetooth integration not ready yet: hci0 (04:7F:0E:25:C5:58): Timed out starting Bluetooth after 15 seconds; Retrying in background
2022-12-11 17:01:12.871 WARNING (MainThread) [homeassistant.config_entries] Config entry '04:7F:0E:25:C5:58' for bluetooth integration not ready yet: hci0 (04:7F:0E:25:C5:58): Timed out starting Bluetooth after 15 seconds; Retrying in background
Have removed the device and re-installed without change.
Any ideas would be appreciated.
TIA
If the Bluetooth integration in your Docker installation of Home Assistant is not working and the logs show a timeout error, it may be due to a conflict with other Bluetooth services on your system.
To resolve this issue, you can try restarting the Bluetooth service on your system by running the following command in a terminal:
sudo service bluetooth restart
This will restart the Bluetooth service on your system, which may resolve any conflicts or errors that are causing the timeout.
Thanks very much, that has resolved the issue.
systemctl restart bluetooth
If you have on HomeAssitant OS updated :wink:
