I’m pretty new with home assistant and i’m running VMware workstation 16 on a Intel NUC which runs an image of home assistant OS 9.5. Home Assistant 2023.2.5, Supervisor 2023.01.1.
USB bluetooth is: DG40s Avantree (Supported and recommended to use for HA)
I’ve installed my Bluetooth adapter on the host windows 11 machine. Loaded up the drivers and can see it in device manager.
In VMware i’ve set it up to share Bluetooth devices with the virtual machine (2023-02-25_18-54-05) but when i go into discover devices nothing shows and when i go to manually add the Bluetooth integration I get “No unconfigured Bluetooth adapters found” .
At this point i’m not sure how to troubleshoot this … ? Thoughts?
